Stationary points (roots) of partially derivated function
brollysan
f(x,y)= ln(x+y) -x^2 - y^2
1. Find the partially derivatives
2. Find the stationary points (roots) of the function
Quite simple, except i don't know what to do with the ln part, this is my attempt tho
f'x= 1/(x+y) -2x
f'y= 1/(x+y) -2y
Is this right? I am not sure what the derivative of ln (x+ c) is c= constant
2. Roots= where the function crosses the x-line right? So I simply set f'x=0 and solve it to get the root?
f'x and f'y are correct. The derivative of ln(f(x)) is f'(x)/f(x). They then want values of x and y where BOTH f'x and f'y equal zero simultaneously. These are the stationary points. Can you find them?
If they both equal zero then they must both equal each other right? Then that means x=y?
F'x=0 = 1/(2x) -2x => 4x^2 =1 => x= 1/4
And since x = y then they must both have a root of 1/4...am i right?
While i am at it i also need help with a limit problem.
The problem, all variables etc
f(x)= x^2 + 2x
find
lim x->a [f(x) - f(a)]/ (x-a)
The attempt at a solution
The correct answer is 2a +2
Factoring etc i got this far:
[(x-a)(x+a) -2a -2x]/(x-a)
Now i can write this as [(x-a)(x+a)]/(x-a) + -2a-2x / (x-a)
Leaving me with x+a -2a-2x/(x-a) I am stuck with this, how do make it so the last part simply becomes 2?
No. x^2=1/4, not x=1/4. And remember quadratic equations generally have two roots. What are the (x,y) pairs that satisfy this?
f(x)= x^2 + 2x
find
Surely you can simplify (-2a-2x)/(x-a). (x-a) is a factor of the numerator.
