- 14,598
- 7,187
Concerning statistical ensemble interpretation (SEI), a lot of confusion has been created and lot of nonsense has been said, especially in a recent thread on "missed opportunities in Bohmian mechanics". Even Ballentine himself said many things about it that do not always seem perfectly clear and self-consistent. I want here to formulate the SEI in a clear, simple and self-consistent way.
The main source of confusion is whether SEI talks about individual systems, or only about large ensembles of systems. In particular, within SEI, does it make sense to say that we have one particle in the state ##|\psi\rangle##?
Let us start from a purely instrumental point of view. Let ##P## be a preparation procedure, defined in terms of actions by an experimentalist in the laboratory. This procedure ##P## usually prepares a small number of particles, typically one particle, or one pair of entangled particles. For simplicity, let as assume that ##P## prepares one particle. If the procedure ##P## is known to a theorist, then for any such ##P## the theorist can write down an abstract density operator ##\rho##. Depending on the ##P##, the ##\rho## can be either pure or mixed. In the rest, for simplicity, I shall assume that it is pure. Thus, to any preparation ##P## of a single particle we can associate a unique (up to an irrelevant overall phase) state ##|\psi\rangle## in the Hilbert space. In this sense ##|\psi\rangle## is associated with a single particle, not with an ensemble of particles.
Above, the crucial assumption is that ##P## is known to the theorist. But what if it is not known, what if the theorist does not know how the particle is prepared? In that case he cannot write down ##|\psi\rangle##. And what if even the experimentalist does not know ##P## (e.g. because ##P## was performed by another experimentalist)? Can the experimentalist perform a measurement, tell the result to the theorist, so that then the theorist can write down ##|\psi\rangle##? The answer is - no! If ##P## is unknown, there is no measurement by which one can determine ##|\psi\rangle##.
Nevertheless, there is a way out. Suppose that the same unknown preparation ##P## can be repeated many times. By repeating it many times, we create a large ensemble of particles. In this case there is a measurement procedure performed on the ensemble by which ##|\psi\rangle## can be determined approximately. Larger the ensemble, better the precision of ##|\psi\rangle## determination. In the limit of infinite ensemble, the determination of ##|\psi\rangle## can be exact. In this sense, ##|\psi\rangle## is associated with a large ensemble of particles, not with a single particle.
To summarize, ##|\psi\rangle## (or more generally ##\rho##) can be associated with a single system when the preparation procedure ##P## is known, but only with a large ensemble of systems when ##P## is unknown. This is the essence of the statistical ensemble interpretation (SEI).
Now someone will note that the above is just the fact accepted by all interpretations. The above is not a particular interpretation. I would say that the above is the minimal SEI. It is minimal, in the sense that it does not add any additional interpretation claims that may create controversy.
However, it does not mean that one cannot add additional interpretation claims to SEI. One can, and one does. One can do that in more than one way, so there is more than one version of SEI. Some versions may tacitly assume existence of additional unknown variables associated with a single system, other versions may deny their existence. Some versions may accept collapse as an information update, other versions may deny collapse in any form. Some versions may view Bell's theorem as a proof of "nonlocality", other versions may view it as a proof of "nonrealism".
What is common to all versions of SEI, except the facts above shared by all interpretations? All versions of SEI have in common the following:
- The collapse does not exist in the physical sense. (The information update is not considered physical.)
- Additional (hidden) variables (e.g. Bohm) are not considered.
