Statistical ensemble interpretation done right
309 replies · 22K views
Simple question said:
But in both cases, the "state as an ensemble" will be tested by a series of individual measurements events, that cannot be reduced nor averaged.
"equivalence class of preparations" is quite vague, as it cannot be equivalent as defined by QM itself (no cloning). Either way that ensemble is the most non-local thing there is in physics.
There's no issue with cloning. We can sketch a theory of a preparation procedure to better understand its meaning by extending our theory to include laboratory degrees of freedom. Consider a microscopic system ##s## in a lab ##L##, and a desired quantum state ##\rho_s(t_0)##. A preparation procedure ##P## is characterised by $$P:= (\rho_{s+L}(t_{-1}), \{C_i\})$$ such that $$\rho_s(t_0) = \frac{\mathrm{tr}_L C_i \rho_{s+L}(t_{-1})C^\dagger_i}{\mathrm{tr}_{s+L}C_i \rho_{s+L}(t_{-1})C^\dagger_i}$$where ##\rho_{s+L}(t_{-1})## is an earlier state of the system + lab and ##\{C_i\}## is an appropriate set of operators. And when we say the state represents a class of procedures, we mean there are many such ##P## that would satisfy the above desired ##\rho_s(t_0)##.
Of course, if we extend our theory to include lab degrees of freedom, it can lead to some peculiar interpretations. The preparation can be associated with a POVM on the lab. Or we might consider an infinite ensemble of similarly prepared labs, of which a subensemble is associated with ##\rho_s##. Some interpretations might even reject such a macroscopic application of Lueder's rule.
Reply
The latter idea may be expensive. Fortunately we don't need a million CERNs all doing once the same scattering experiments. It's fine to have one CERN and using its equipment to perform a million pp collisions ;-)).
But by reading the many interpretation (of SEI flavors) explained by many people here, I am still looking for at least once factual problem that it addresses (except maybe the strong embedded denial that could help someone sleep at night), or only the vaguest way that map would relate to the territory.
Ballentine argues that it eliminates assumptions that i) play no role in the application of quantum theory, and ii) lead to conceptual difficulties with measurement processes.
Reply
gentzen said:
Or maybe you are unhappy because I also used the word "system" in that sentence.
vanhees71 said:
I'm unhappy about your formulation
The degrees of freedom and the Hilbert space you choose to describe them says something about what you intent to measure on the system.
because it seems to state a very common misconception about quantum mechanics. It seems as if you have an interpretation of the Heisenberg uncertainty relations in mind as if it would prevent from meausring the one or the other observable with arbitrary precision. This is, however, in no way what's implied by the uncertainty relation. I can always measure any observable of a system with as high a precision I want, and I'm not in any way restricted in the ability to choose to measure any observable of the system I like due to the state preparation.
On rereading this, I see again why I didn't know how to respond. One thing I could do is to explain the concrete example I had in mind:
When you describe a Stern-Gerlach experiment, your magnet may be described as fixed such that the magnetic field (except for its inhomogenity) points in z-direction, or you may describe it such that the magnet can be rotated around the particle beam. In the second case, you probably need to allow density matrices to describe the actual state of the incoming particles. But most introductory QM textbooks have not yet introduced density matrices at the point where they describe and analyse SG, so they typically go with the description using a fixed magnet. Independent of this, the silver atoms have more degrees of freedom in their quantum state than just the spin of the unpaired electron in the outer shell. But we won't describe those in our Hilbert-space for analyzing SG, because we don't intent to measure anything for which they would be relevant.
Another thing I could do is to explain why I participated in this unhappy discussion at all:
Morbert tried to explain some distinctions, and because we both have some "background" in the consistent histories interpretation, I thought I could help. Or at least, I didn't want to distance myself (more than I already did here and here) from that interpretation by staying silent.
vanhees71 said:
The uncertainty relation also does not say anything about the disturbance of the system by measurement. It can't, because it's a fundamental principle derived without any reference to a specific measurement procedure, and how the system is disturbed by the interaction with the measurement apparatus of course depends on the specific device.
This was the actual reason why I still wanted to respond, because here you highlight a specific misconception of Heisenberg from his paper "Über den anschaulichen Inhalt der quantentheoretischen Kinematik und Mechanik". I noticed that I never asked you whether you have any concrete papers (like the one above or his Solvay paper with Born) or books (like "Physics and Philosophy" or "Physics and Beyond") in mind when you say that Heisenberg is responsible for much of the confusion about QM. Here is a summary of some of his works, maybe it simplifies your "selection process":
https://www.informationphilosopher.com/solutions/scientists/heisenberg/
My own interpretation what you dislike about Heisenberg was his focus on the role of the observer (to which I can agree to the extent that it neglects the role of preparation and control), and also quite general his passion for philosophy.
Once more, this is a misconception of the quantum state. The quantum state of the system you want to observe has nothing to do with the measurement device but with the preparation of this system. E.g., in the original Stern-Gerlach experiment the Ag atoms were prepared by letting Ag vapor stream out of a small hole in an oven. Indeed, this preparation procedure is described by a corresponding mixed state of Ag atoms.
You can direct your magnet independent of how you prepare the Ag atoms and thus you can measure its spin component in any direction given by the magnetic field you like. The state in this specific experiment indeed has to be described by a Ag-atom beam, prepared in a mixed state, no matter whether you fix the field in one direction or another.
I don't know enough about the consistent-history interpretation to comment on this. I've once read about it and didn't find it in any way convincing compared to the minimal statistical interpretation, which reflects how QT is used in the physics community when discussing real-world experiments and not some philsophical isms...
For me Heisenberg and Bohr wrote the most incomprehensible papers compared to the other "founding fathers" of QT. Particularly matrix mechanics has been worked out by Born and Jordan in crystal-clear mathematical form, quickly followed by Pauli's derivation of the hydrogen spectrum using matrix mechanics. These authors are a much better read than Heisenberg and Bohr if you like to investigate the early development of this branch of the first discovery of modern quantum theory. This also includes the famous 2nd part, the "Dreimännerarbeit", written together by Born, Jordan, and Heisenberg. Heisenberg had ingenious ideas but always needed translators to clarify his insights for the normal physicist. This usually were Born and Jordan but also very much Pauli.
The most underrated of all these was Born, who was really the one recognizing the mathematics behind Heisenberg's weird Helgoland paper, which reflects the discovery process of the Göttingen group pretty nicely. Also see
https://arxiv.org/abs/2306.00842
https://doi.org/10.1140/epjh/s13129-023-00056-1
What I dislike is his nebulous writing and overemphasizing philosophy over physics. He also had many misconceptions, which for some reason unfortunately still stuck in modern textbooks (although they don't play much of a role anymore in contemporary research), e.g., his first paper about the meaning of the uncertainty relation, which he first published claiming it were about the disturbance of the system by interaction with the measurement device, which leads to the misconception discussed in the first part of this posting. This was corrected immediately thereafter by Bohr, who was even more nebulous in his writing but often had the better physical instinct.
The disturbance of the system by measurement is of course also an important point following from the atomistic structure of matter. E.g., you cannot have an arbitrary small "test charge" to measure an electromagnetic field. You need at least one particle with 1e charge to probe the field, which inevitably disturbs it on these "microscopic scales". To describe this is much more complicated an after all can only be done for specific experimental setups analyzing the dynamics of the measurement process under investigation.
As far as I recall reading som the historical descriptions, there was a early internal tension in the Copenhagen group, where Heisenberg focused more on the individual "observer", but while Bohr suggested that it's all of the classical reality taken together, that is the foundation for preparation, control and observeation. This doesn't mean Heisenberg was wrong and Bohr was right, as I understand it both views were unified because the internal communication within the classical domain is "trivial" as information can be copied/shared at least in principle, and that all different classical observes supposedly will AGREE on what actual records are. So Bohr and Heisenbergs views was consistent. (The dispersion of observations within classical world, is that due to special relativity, which of course wasnt what Bohr worried about, but to the extent QFT solves this, the conceptual idea of CI still holds).
So as I see it the idea is that the macroscopic measurement device is always "in tune" with the information implicit in the preparation and control of the source; as well as any prior information from process tomograpghy to determine hamiltonians etc. Changing of a dial at the detector, does not change the preparation. In this case the observer is always in principle "informed" about the preparation - via the classical communication channels. There is nothing that prevents this. Any issue between difference classical measurement devices are if nothing is wrong, supposed to be resolved by the state transformation of SR.
This is all conceptually fine, as long as we have the classical background spacetime and macrocsopic reality to back this up. I think of the "statistical interpretaion" as beeing litteraly processed and encoded in the macroscopic environment as well. So for me, the statistical interpretation are not really at face with CI. I think they get alon fine. The statistcal information, is the "knowledge of the obsever", and it is encoded in the macroscopic environment?
/Fredrik
Not really, since, as @gentzen correctly pointed out, the usual description only includes the outermost electron of the Ag atoms and leaves out the other degrees of freedom. So really the usual description of the state is a mixed state of qubits. (I say "qubits" instead of electrons because the description does make use of the fact that the Ag atoms are electrically neutral so there is no Lorentz force term in the Hamiltonian describing the interaction with the SG magnets, and therefore the only relevant interaction is the magnetic coupling to the spin-1/2 degree of freedom; for actual electrons that would not be the case.)
vanhees71 said:
The system is what I'm investigating, e.g., an electron.
Is the system "an electron" or "an ensemble of similarly prepared electrons"? Whether you use a single CERN or one million CERNS, do the results of the measurements tell you about "an electron" or "an ensemble of similarly prepared electrons." (or preparation procedure).
Reply
That depends on which QM interpretation you are using. In statistical ensemble interpretations such as the OP describes, yes, the quantum state refers to an ensemble of electrons (more precisely, the spin-1/2 degree of freedom of the outermost electron in neutral silver atoms) all coming from the same preparation process.
Same answer as above.
Reply
PeterDonis said:
That depends on which QM interpretation you are using. In statistical ensemble interpretations such as the OP describes, yes, the quantum state refers to an ensemble of electrons (more precisely, the spin-1/2 degree of freedom of the outermost electron in neutral silver atoms) all coming from the same preparation process.Same answer as above.
Thank you, but the question was for vanhees in response to his statement that "the system" was "an electron", which implies a different interpretation than what I remember him using previously.
In post #67 he seems to be using an interpretation in which the quantum state describes the preparation procedure directly, as opposed to describing either an individual system produced by that procedure or an ensemble of such systems. But I agree it would be good for him to clarify.
Reply
There are indeed interpretations where the quantum state of the system has nothing to do with what I intent to measure on the system. But if a minimal statistical interpretation wants to keep some "operational verification" meaning, then it has to be a bit more careful at that point:
gentzen said:
If you look at SEI from an operational verification perspective, then yes, you must associate a single system with a state before you know the results of the non-preparation measurements. This allows it to take part in some verification. Of course, no statistical verification can ever fully reject your state assignments, at most it can tell you that winning the jackpot of a lottery would have been more probable than your obtained measurement results given your previous state assignments.
The issue arises, because the statistical verification requires a limit process of accumulating measurement statistics. But this limit process requires that the equivalence classes of preparation procedures are kept fixed during the verification. And what I intent to measure on the system can impact those equivalence classes.
Now I admit that "good taste" allows to relax those "rules" significantly in practice. But the idealized description should still be the one explained above. It is simply too easy to fool oneself with statistics, not least because our human intuition is not very good in that domain.
vanhees71 said:
For me Heisenberg and Bohr wrote the most incomprehensible papers compared to the other "founding fathers" of QT. ... Heisenberg had ingenious ideas but always needed translators to clarify his insights for the normal physicist. This usually were Born and Jordan but also very much Pauli.
Indeed, looks like Heisenberg needed both Born and Pauli. Jordan, not so sure, the paper is consistent with what I learned from other sources. He didn't do himself a favor by being cavalier with truth. Maybe Paul Ehrenfest is even more underrated than Born:
Einstein’s enduring estimate appears in his response to a letter from Paul Ehrenfest. To Ehrenfest’s remark that, despite his relative nothingness, Einstein and Bohr had always supported his work, "whereas contact with other theorists totally discourages me," Einstein replied that like himself and Bohr, Ehrenfest was a Principienfuchser, a worrier about foundations, while most other theorists were virtuosi, polished mathematicians or devotees of detail, but not quite the real thing. He gave as examples of the polished virtuoso Born and his predecessor at Göttingen, Debye.
The award of the Nobel prize to Born in 1954 made a perfect emblem of the “great adventure." It brought out the main distinguishing feature of the new physics, its radically probabilistic basis, and implied its coherence and completeness by rewarding the co-inventor of MM for his elucidation of its rival WM. The earlier reservations about Born's contributions were ignored or forgotten. And so the Nobel establishment gave a fifth prize for wave mechanics, including those awarded in 1937 for the "experimental discovery of the diffraction of electrons." MM could boast but one.
Well, thanks for answering me. I understand that you dislike his overemphasizing philosophy over physics. The general accusation of nebulous writing without reference to concrete papers or books suggests to me that you actually have not read much of his writings. Perhaps you tried to read his breakthrough paper, and didn't get what you hoped for.
Trying to turn one concrete misconception into a general accusation of many misconceptions again suggests to me that you are simply not very familiar with much of Heisenberg's work. Maybe you would also cite his infamous unified field theory of elementary particles as another example of his misconceptions. But both concrete misconceptions are common knowledge concerning Heisenberg, not an indication of any non-trivial familiarity with this work.
Anyway, thanks again for your answer. I always have to force myself to write an answer in cases where I am not so sure about my answer, because I know that it would be impolite if I just stayed silent. But still, sometimes staying silent is actually a good idea.
Yes.
No, it doesn't. You can do different measurements on systems that were prepared by the same preparation procedure. The preparation procedure (or equivalence class of such procedures--but in the case under discussion, the SG experiment, there was only one preparation procedure so the "equivalence class" question is moot) is modeled by the quantum state. The measurement you make is modeled by an operator. The two are distinct and independent.
Reply
Here I found a favorable account of Jordan's contributions:
It was Jordan, more than anyone else, who developed a mathematically elegant formulation of matrix mechanics (Born and Jordan 1925; 1926). It was Jordan who went on to consolidate matrix mechanics with Dirac’s alternative operator calculus (Dirac 1925) and Erwin Schrödinger’s wave-mechanical formulation (Schrödinger 1926a; 1926b) in the comprehensive formalism known as statistical transformation theory (Jordan 1927a; 1927b, see also Duncan and Janssen 2009). It was Jordan who did more than anyone other than Dirac to inaugurate the program of quantum field theory, in ways such as developing the second quantization approach and being the first to discover the problem of divergences in quantum field theory (Jordan and Klein 1927; Jordan and Wigner 1928). And it was Jordan who, along with von Neumann and Eugene Wigner, was developing more abstract algebraic frameworks for quantum mechanics (Jordan 1933b; Jordan et.al. 1934).
But in case you believe that Jordan was less deep into philosophy than Heisenberg, see:
https://www.informationphilosopher.com/solutions/scientists/jordan/
To stay with the SG experiment, should a different isotope composition of the beam of silver atoms be considered to be a different preparation procedure? It doesn't matter for the correlation between spin and momentum. It has a slight impact on the correlation between momentum and position. And if it were important to us, we could simply measure the isotope composition of "our" beam. For some experiments, it might even be important for the beam to consists only of a single isotope, because of its impact on the exact trajectory.
The quantum state is the formal description of a preparation procedure on a single system. In this sense the quantum state refers to the single system. The meaning of the quantum state is, of course, entirely statistical, i.e., the possible outcome of any observable is given by Born's rule, i.e., the possible outcomes are the eigenvalues of the self-adjoint operator, representing the measured observable, ##\hat{O}##. Then let ##|o,\alpha \rangle## be the complete orthonormal set of eigenvectors of ##\hat{O}## with the eigenvalue ##o##, then given the quantum state ##\hat{\rho}##, the probability to get ##o## when measuring ##O## (the observable is defined by a measurement procedure) then is given by
$$P(o|\hat{\rho})=\sum_{\alpha} \langle o,\alpha|\hat{\rho}|o,\alpha \rangle.$$
This can, of course, only be verified experimentally by preparing an ensemble of independently prepared systems in the state described by ##\hat{\rho}##.
That's the standard interpretation and practice in real-world physics laboratories. There's some preparation procedure (e.g., set up a Ag-atom beam by heating up silver in an oven with a little hole, letting it go through some slits to collimate it, etc.) and independently you can measure any observable on the so prepared system you like (e.g., the component of its spin in an arbitrary direction by putting a corresponding magnetic field in this direction and a screen registering the Ag atoms at the corresponding places behind the magnet; the magnet entangles the spin component with the position at the screen modulo some small systematical error since the inhomogenous magnetic field has at least a small component in a different direction).
Of course, the preparation procedure has to be kept fixed to get an ensemble described by the intended state you want to investigate.
I've no clue, what you mean by this. This has nothing to do with QT but holds for any statistics, including "classical statistics".
Jordan was behind most of the math. E.g., he helped born to prove the famous commutation relation between position and momentum, he developed em-field quantization (in 1925/26 before Dirac!), etc. He is the most underrated of the founding fathers of QT. That's partially, because he was "too mathematical" for the taste of many physicists but also because he was foolish enough with his political involvement with the Nazis in 1933-1945.
I read the Helgoland paper. Of course, you can understand it, having learnt the elaborated theory nearly 100 years later. If you, however, try to understand it without assuming this knowledge, it's hopeless. Matrix Mechanics was worked out in clear mathematical form by Born and Jordan (of course under participation of Heisenberg) shortly afterwards.
Sure, it's telling. Pauli withdraw his name from the paper before publication. I think I'm quite famliar with QT in a hopefully not too trivial way ;-).
Well, one can only learn something in these matters by discussions.
If I prepare single-electron states, I deal with a single electron. Of course, as with any experiment, I have to prepare and entire ensemble of a single-electron state to verify the probabilistic predictions implied by this preparation. I don't need a million of CERNs to prepare an ensemble of proton or heavy-ion beams. This I can do with 1 CERN as is done in the real world ;-)).
Just a side comment, that this is just one possible interpretation. I know that you are clarifying what you view is, but there are other possibilities. For example you have interpretations where the state describes the ensemble of equally prepared systems, not any single system.
Reply
This is not an interpretation, that's how QT is used in analyzing real experiments.
To build an ensemble you have to prepare single systems independently from each other. So there must be a meaning of "state" for a single system, and that's the preparation procedure (or rather an "equivalence class of preparation procedures") applied repeatedly to many single systems to prepare an ensemble.
Since the physical meaning described by the state, ##\hat{\rho}##, is entirely probabilistic, you can say that it indeed describes an ensemble in the sense that the probabilities it predicts, can only be observed on (sufficiently large) ensembles, but to build the ensemble you have to refer to each single member of this ensemble, and that leads to the operational meaning of the state as a preparation procedure.
Reply
  • Skeptical
No, it is an interpretation. I think you are confused about it, and you don't see the difference.
The ensemble in this interpretation is an abstract entity. You don't build it. You cannot build it. It is an equivalent class, it ha infinitely many members.
Why there must be? Just because you prefer it that way?
And as I said, there infinitely many members in the ensemble, what do you mean by "build it"?
Reply
I in part agree, but isnt the probabilistic embedding of a single instance as well?
But approximately information encoded in the macro environment (rhe lab and all its computers) is real, and not an astraction. Its how i would defend this.
/Fredrik
Reply
How about that the environment(observer) is "learning" about what state distribution the preparation produces. Building ~ learning, tuning the procedure? Makes sens to me.
/Fredrik
Reply
It's not an abstract entity, it's a real-world item to be investigated with real-world experimental setups.
You must be able to associate the abstract entity ##\hat{\rho}## ("statistical operator") of the formalism with the real-world system you want to investigate, and that's the preparation procedure done on this system in the real-world experiment you do with it.
In a real-world experiment there's a finite ensemble, and you have the corresponding statistical errors (in addition to the usually also apparent systematical ones) when comparing the predicted probabilities to the measured averages over a finite ensemble.
Reply
  • Sad
You are simply making claims based on a different interpretation instead of providing any arguments!!! You cannot reject one interpretation using another!
Reply
How would one(an observer or a physicists) alternatically practically or operationally determine/define the probabilistic description of a single system by any level of confidence? unless history repeats itself. In a way one might say that provided that field quanta are indiguishable, can we really say wether history DID repeat itself, or if we observed the "same thing once again", without using auxiliary information? (would that be cheating btw?)
/Fredrik
What do yiu mean by that? Once the system is prepared, you can make only one measurment. After that the system is no longer in the same prepararion.
/Fredrik
Reply
  • Haha
That would depend on how much detail about the state you want to represent. In the usual treatment of the SG experiment, all the details that the isotope composition can affect are left out.
