Statistics: paried observations
  • Thread starter Thread starter k77i
    Statistics
The discussion revolves around calculating a 95.8% confidence interval for the difference in LDL cholesterol levels before and after taking a new medication. The problem involves paired observations from a sample of 10 individuals.
  • Participants discuss the calculation of the sample mean difference and the sample standard deviation of the differences. There are questions about the accuracy of the standard deviation used and the resulting confidence interval.
Some participants have provided alternative calculations and suggested checking for errors in the original calculations. There is an ongoing exploration of the correct values for the sample standard deviation and confidence interval.
There is mention of using different software (Excel and Maple) for calculations, indicating potential discrepancies in results. Participants are questioning the assumptions made regarding the standard deviation and the calculations performed.
k77i
To test the efficacy of a new cholesterol-lowering medication, 10 people are selected at random. Each has their LDL levels measured (shown below as Before), then take the medicine for 10 weeks, and then has their LDL levels measured again (After).
Before After
195 175
131 129
141 105
182 184
173 138
123 120
147 115
156 144
125 87
161 137
Give a 95.8% confidence interval for meanB - meanA , the difference between LDL levels before and after taking the medication.
d(bar) - t(alpha/2)(Sd/sqrt(n)) < meanDifference < d(bar) + t(alpha/2)(Sd/sqrt(n))
I found all the values using excel:
d(bar) = 20
t(alpha/2) = 2.368676
Sd = 190.36
n = 10 (given)
and my answer was (-122.586 < meanDifference < 162.586)
but this is incorrect
Before After
195 175
131 129
141 105
182 184
173 138
123 120
147 115
156 144
125 87
161 137
d(bar) = 20
Sd = 190.36
n = 10 (given)
I don't know what your Sd is, but if it is the sample standard deviation of the difference, then it is wrong. I get sample mean difference = m = 20, sample standard dev. of diff. = s = 15.3695 (your Sd?). This gives a confidence interval very different from yours.
RGV
yes it was the standard deviation of the means and I don't get why it would be wrong, I used excel to calculate it..
Anyways the correct interval was (8.5,31.5)
I first used Maple to do the calculation. Then, to see if Excel was giving you the trouble, I re-did the analysis using Excel. It agreed with the Maple calculation and disagreed with yours. I suggest you search for a typo or something similar.
  • · Replies 24 ·
  • · Replies 28 ·
  • · Replies 61 ·
13K
  • · Replies 125 ·
21K
