Step response to an impulse response
The discussion revolves around finding the step response of an LTIC system with a specified impulse response, h(t) = u(t) - u(t-2). The user initially struggles with the integration process needed to derive the step response, which involves integrating h(t) over the range from -∞ to t. Despite the challenge, the user eventually resolves the issue independently. The conversation highlights the importance of understanding the relationship between impulse and step responses in system analysis. The user expresses gratitude for the eventual clarity achieved in solving the problem.
EeCe
Hi all,
I'm having a lot of trouble understanding this step response:
Problem statement:
Consider an LTIC system with impulse response given by: h(t) = u(t) - u(t-2)
Sketch the step response s(t).
I've already sketched h(t)...but,
I know that the step response is found by integrating h(t) with respect to tau over the range -∞ to t. I know this is not hard, but for some reason I'm just having trouble figuring out what to do, and my text doesn't cover the step response at all (probably because it's so easy).
Any help if how to find the step response would be appreciated. Thanks
Well, I figured out on my own.
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 17 ·
