Steps to solve this differential equation
  • Thread starter Thread starter xmenus
    Differential
12 replies · 2K views
xmenus
Hi ,
Can anyone help me on this problem please?!
Answer is given but i want to know steps to come to it, i think i tried a lot to solve it but i couldn't come to the given result.
Thanks to all
hi xmenus! welcome to pf! :wink:
show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
Here's the link of doc..I think i tried loop method and many other forms but... here i just showed the analogy i tried but i couldn't come to the result.(First circuit is different one)
I took an other example just to show or ask if the other circuit can be solved with the same analogy?!
https://www.dropbox.com/sh/7g4vmpl4uhjbyl4/wwNdGrKm5o
it's rather difficult to read :redface:
anyway, what is D ? :confused:
That's a tough circuit you posted for finding a differential equation.
Don't know for sure...but perhaps a node analysis on the upper right hand node? Current in equal current out sort of thing.
Using SL and 1/(SC) may simplify things as well.
ah, D = d/dt !
ok, you've replaced C and R3 (in series) by an impedance Z1
(btw, wouldn't Z3 be an easier name to keep track of? :wink:)
then you've replaced R2 and Z1 (in parallel) by Ze
but then you've stopped (presumably you're going to replace L and Ze, then replace that and R1?)
well, that looks fine so far :smile:
what's the difficulty?​
The problem is that it's not working like that.I can't come to the result, i don't know!?
but you stopped, you only got as far as Ze :confused:
No,actually i worked on it till to the end but the result i got is not like the given one.
You are right, i didnt post other steps,but on that way it didnt work!
we can't comment on why it didn't work unless you show us what you did
Finally,after many attempts, i solved it :D !
I might post the solution so anyone can find it useful maybe.
Thank you a lot anyway,and thank for your time!
