How Are Stieltjes Polynomials Related to Legendre Polynomials?
  • Context: Graduate
  • Thread starter Thread starter member 657093
    Polynomials
The discussion focuses on the relationship between Stieltjes polynomials and Legendre polynomials, specifically seeking a recurrence relation or defining expression for the Legendre-Stieltjes polynomials. It is established that the Legendre-Stieltjes polynomials do not conform to a simple three-term recurrence relation, as indicated by various articles referenced, including one from the American Mathematical Society. The defining expression for the Legendre-Stieltjes polynomial is given by the integral condition involving Legendre polynomials, which complicates the derivation of coefficients for the polynomial.
  • Understanding of orthogonal polynomials and their properties.
  • Familiarity with recurrence relations in polynomial sequences.
  • Knowledge of integral calculus, particularly in evaluating definite integrals.
  • Basic understanding of polynomial approximation and numerical methods.
  • Research the properties of Stieltjes polynomials in relation to Legendre polynomials.
  • Study the numerical methods for solving systems of equations arising from polynomial definitions.
  • Explore the use of Mathematica for symbolic computation of polynomials.
  • Investigate Gaussian quadrature and its applications in polynomial approximation.
Mathematicians, researchers in numerical analysis, and students studying orthogonal polynomials and their applications in approximation theory.
member 657093
TL;DR
orthogonal polynomials, Legendre polynomials
I am looking for a recurrence relation and/or defining expression for the Stieltjes polynomials with regard to the Legendre polynomials. I found an article about it here: Legendre-Stieltjes but they do not offer a formula.
For example a recurrence relation for the Gegenbauer polynomials is here: Gegenbauer under the second bullet point.
An example of a defining expression for the Jacobi polynomials is here: jacobi using hypergeometric function.
There is another article that deals with Stieltjes polynomials with regard to the Legendre function of the second kind here: Legendre function-Stieltjes found at the first set of Mathematica code. However as I don't understand the code, I don't really know what is the generating formula there.
Mathematics news on Phys.org
From some internet browsing this morning:
Articles such as http://www.mi.sanu.ac.rs/~gvm/radovi/f18-02.pdf state:
Orthogonal polynomials on the real line always satisfy a three-term recurrence relation.
However, the link you gave states:
The Legendre-Stieltjes polynomials do not satisfy three-term recurrence relations or have a particulary simple representation.
The link you gave defines the ##(n+1)##th Legendre-Stieljes polynomial ##E_{n+1}## by:
##\int_{-1}^{1} E_{n+1} P_n(x) dx = 0## for ##n = 0,1,2,..n## where ##P_n(x)## is the ##n##th Legendre polynomial. [ Edit: correction ##\int_{-1}^{1} E_{n+1}P_k(x) x^k = 0## for ##k = 0,1,2,...n##] As I visualize finding ##E_k## directly from that definition it would entail solving a system of ##k## equations in ##k## unknowns for the coefficients of ##E_k##.
The link you gave cites the article https://www.ams.org/journals/mcom/1968-22-104/S0025-5718-68-99866-9/S0025-5718-68-99866-9.pdf. The remarks after eq. 3 indicate that solving the system of equations runs into problems of numerical accuracy. I don't know if those problems still exist in modern implementations of high precision arithmetic. If they do, then we could try to figure out the complicated looking methods described in that article following eq. 3.
Yes, the article indeed says that there is neither a recurrence relation nor a simple representation. Can you please formulate the problem in math symbols and equations to find the system of k equations? Or else do you understand what they say their program does in order to find the Legendre-Stieltjes polynomials at the end? Something about constructor...it looks easy by the sound of it!
Otherwise there is a ready made computation in my last link which instead of finding the Stieltjes polynomials through the Legendre polynomials, it finds it through the Legendre function of the second kind. However their code is in mathematica. And I don't quite understand what the power series is doing?
The code is here:
[CODE title="stieltjes polynomials"]SetAttributes[StieltjesE, Listable];
StieltjesE[n_Integer, x_] := Module[{xl},
Set @@ Hold[StieltjesE[n, xl_],
Normal[Quiet[Series[4^(n - 1) Beta[n, n]/
LegendreQ[n - 1, 0, 3, xl],
{xl, ∞, 0}],
Series::sbyc]]];
StieltjesE[n, x]][/CODE]
Is it doing the following:
E_{n}(x)= \sum_{k=0}^n 4^{k-1} {\frac {Beta(n,n)} {LegendreQ(k-1,0,3,x)}}
One of the principles of Algebra is that there is a nobility in suffering. I follow that principle only to a limited extent. I'll try an example showing one of the equations for one of the polynomials.
Consider the case ##n = 3, k = 2##
Let ##E_4(x) = c_4 x^4 + c_3 x^3 + c_2 x^2 + c_1 x + c_0 ##
where the ##c_i## are the unknown coefficients.
I didn't quote the correct definition for ##E_n## in my previous post. The correct definition is that:
##\int_{-1}^{1} E_{n+1}(x)P_k(x) x^k dx = 0 ## for ##k = 0,1,...n##So for ##n =3## :
##E_4(x) = E_{3+1}(x) ## satisifes ##\int_{-1}^{1} E_4(x) P_k(x) x^k dx = 0 ## for ##k = 1,2,3##
To Derive the equation for the case ##k = 2## :
##P_2(x) = \frac{1}{2} (3 x^2 - 1)##
Let ##f(x) = E_4(x) P_2(x) x^ 2 = (c_4 x^4 + c_3 x^3 + c_2 x^2 + c_1 x + c_0)(1/2)(3x^2 -1 ) x^2 ##
## = (1/2) \ ( \ c_4 (3x^6 - x^4) + c_3(3x^5 - x^3) + c_2(3x^4 - x^2) + c_1(3x^3 - x) + c_0(3x^2 - 1)\ ) (x^2)##
## = (1/2) \ (\ c_4( 3x^8 - x^6) + c_3(3x^7 - x^5) + c_2(3x^6 - x^4) + c_1(3x^5 - x^3) + c_0(3x^4 - x^2) \ )##
The antiderivative of ##f(x)## is:
##F(x) = \int f(x) dx = (1/2)\ (\ c_4( 3 \frac{x^{9}}{9} - \frac{x^7}{7}) + c_3(3 \frac{x^8}{8} - \frac{x^6}{6}) + c_2(3 \frac{x^7}{7} - \frac{x^5}{5}) + c_1(3 \frac{x^6}{6} - \frac{x^4}{4}) + c_0( 3 \frac{x^5}{5} - \frac{x^3}{3})\ )##
##\int_{-1}^1 f(x) dx = F(1) - F(-1) ##
##= (1/2) ( c_4 (3/9 - 1/7 ) + c_3(3/8 - 1/6 ) + c_2(3/7 - 1/5 ) + c_1 (3/6 - 1/4 ) + c_0(3/5 - 1/3)##
##\ \ - (1/2) ( c_4( -3/9 + 1/7) + c_3( 3/8 - 1/6) + c_2(-3/7 + 1/5) + c_1 (3/6 - 1/4) + c_0(- 3/5 + 1/3) \ )##
## = (1/2) ( c_4( 6/9 - 2/7) + c_3(0) + c_2( 6/7 - 2/5) + c_1(0) + c_0(6/5 - 2/3)\ ) ##
Setting the above expression to zero gives the equation for ##k = 3## which is:
(6/9 - 2/7) c_4 + (6/7 - 2/5) c_2 + (6/5 - 2/3) c_0 = 0 ##
You should check my work. I don't have a reference to check it against.
No, I don't. The documentation you linked does not give the code for the constructor. It only shows the syntax for calling it.
I don't use Mathematica, so I don't know what that code does.
For n=3 and k =1:
## c4(2/7)+c2(2/5)+c0(2/3)=0##
for n=3 and k =2:
##c4(6/9 - 2/7)+c2(6/7 - 2/5)+c0(6/5 - 2/3) = 0##
and for n=3 and k=3:
##c4(10/11 - 6/9)+c2(10/9 - 6/7)+c0(10/7 - 6/5) = 0##
But how do you find the coefficients if you are setting the 3 equations to equal 0?
BTW, I think you should multiply the equations for k=2 and 3 by (1/2) !
It's a system of 3 simultaneous equations in 3 unknowns. Have you studied solving simultaneous linear equations?
Multiplying or dividing both sides of an equation by a constant won't change its solutions.
The link you gave https://www.boost.org/doc/libs/1_66.../math_toolkit/sf_poly/legendre_stieltjes.html says:
E4(x) = P4(x) - 20P2(x)/27 + 14P0(x)/891
So ##c_3 = c_1 = 0 ## since the Legendre polynomials involved only have even powers.
We didn't get this conclusion merely from using the definition
##\int_{-1}^{1} E_4 P_k(x) x^k = 0 ## For ##k = 0,1, 2, 3## (The link says ##k = 0, 1,2...## Other articles on the web begin with ##k = 1##)
So the condition ##\int_{-1}^{1} E_4 P_k(x) x^k## is a property of ##E_4## and not a definition of ##E_4##.
To understand a definition of ##E_n## we need to understand the first paragraphs of the link
This has to do with Gaussian quadrature and I don't understand those paragraphs yet.
Yes I can solve any n simultaneous equations by matrix operations but as I said if all 3 equations = 0, all the coefficients will also equal 0.
Stephen Tashi said:
∫1−1f(x)dx=F(1)−F(−1)∫−11f(x)dx=F(1)−F(−1)\int_{-1}^1 f(x) dx = F(1) - F(-1)
=(1/2)(c4(3/9−1/7)+c3(3/8−1/6)+c2(3/7−1/5)+c1(3/6−1/4)+c0(3/5−1/3)=(1/2)(c4(3/9−1/7)+c3(3/8−1/6)+c2(3/7−1/5)+c1(3/6−1/4)+c0(3/5−1/3)= (1/2) ( c_4 (3/9 - 1/7 ) + c_3(3/8 - 1/6 ) + c_2(3/7 - 1/5 ) + c_1 (3/6 - 1/4 ) + c_0(3/5 - 1/3)
−(1/2)(c4(−3/9+1/7)+c3(3/8−1/6)+c2(−3/7+1/5)+c1(3/6−1/4)+c0(−3/5+1/3) ) −(1/2)(c4(−3/9+1/7)+c3(3/8−1/6)+c2(−3/7+1/5)+c1(3/6−1/4)+c0(−3/5+1/3) )\ \ - (1/2) ( c_4( -3/9 + 1/7) + c_3( 3/8 - 1/6) + c_2(-3/7 + 1/5) + c_1 (3/6 - 1/4) + c_0(- 3/5 + 1/3) \ )
=(1/2)(c4(6/9−2/7)+c3(0)+c2(6/7−2/5)+c1(0)+c0(6/5−2/3) )=(1/2)(c4(6/9−2/7)+c3(0)+c2(6/7−2/5)+c1(0)+c0(6/5−2/3) ) = (1/2) ( c_4( 6/9 - 2/7) + c_3(0) + c_2( 6/7 - 2/5) + c_1(0) + c_0(6/5 - 2/3)\ )
(1/2) here is missing. Sympy says that k=2 = ##c4* 4/21##
which is (6/9 -2/7) *0.5
Are you saying that is true only for these particular 3 equations? - or are you saying it is true for any 3 equations whose right hand side is zero?
Ok..there is homogeneous type...but it is really complicating matters, if I have to set the constants at 0!
What I meant before, normally we would have trivial solutions where all coefficients are zero as well!
I quoted the definition incorrectly even in my edit!
The definition says ##\int_{-1}^1 E_{n+1} P_n(x) x^k = 0## for ##k = 0,1,2,...,n##. There is no ##k## subscript on ##P_n(x)##. So for the case ##n = 3, k = 1## we use ##P_3(x)##. We don't use ##P_1(x)##. Which ##P## did you use?
I realized this while transcribing quotations from https://www.ams.org/journals/mcom/1968-22-104/S0025-5718-68-99866-9/S0025-5718-68-99866-9.pdf. as a way of forcing myself to read them carefully.
2. The Extension of Quadrature Formulae. The basic reasoning behind the extension of quadrature formulae is as follows. Let an n-point formula be augmented by the addition of p abscissae and let ##G_{n+p}(x) ## be the polynomial whose roots are the ##n + p## abscissae of the new quadrature formula. A general polynomial of degree ##n + 2p -1## can be expressed as
##(1)\ ## ##F_{n+2p-1}(x) = Q_{n+p-1}(x) + G_{n+p}(x) + \sum_{k=0}^{p+1}C_k x^k##
where ##Q_{n+p-1}(x) ## is a general polynomial of degree ##n+p-1##. This transformation of ##F_{n+2p-1}(x)## is possible since the number of unknown coefficients on the left- and right-hand sides of (1) is equal. ##\ Q_{n+p-1}(x) ## can always be exactly integrated by a ##(n + p)##-point formula and if ##G_{n+p}(x)## is such that
##(2)\ \ ## ##\int_{-1}^1 G_{n+p}(x)x^k dx = 0, \ k = 0,1,..., p-1##
then all of (1) can be exactly integrated by an ##(n + p)##-point quadrature formula.Thus it should, in principle, be possible to derive formulae having ##n+p## abscissae and of degree ##n + 2p - 1##.
2.1. The Extension of the Gauss Formulae. Kronrod [1] has considered the case ##p = n + 1## for the n-point Gauss formula.
For this choice of ##p## the polynomial ##K{n+1}(x)## whose ##n + 1## roots are the additional abscissae must satisfy, corresponding to (2),
##(3)\ \ ## ##\int_{-1}^{1} K_{n+1}(x)P_n(x)x^k dx = 0## for ##k = 0, 1,..., n##
, where ##P_n(x) ## is the Legendre polynomial. Kronrod determines ##K_{n+1}(x)## and hence its zeros by substituting its polynomial expansion into (3) and solving the resulting triangular system of equations to find the polynomial coefficients. It is at this point that the numerical difficulties arise.
1. A. S. Kronrod, Nodes and Weights of Quadrature Formulas, English transl. from Russian, Consultants Bureau, New York, 1965. MR 32 #597
I used the Legendre polynomials as the paper suggested, with reference to your help on how to go from the integration from -1 to 1 to a system of equations with constants = 0 and I solved it...
[CODE lang="python" title="stieltjes polynomials"]for k in range(1,r):
b = legpoly(x,2*k-1)
c = legpoly(x,n)
print
print "k = ",k
print "------"
for i in range(1,r+1):
s = a+ str(m-i)
f = (b*c*legpoly(x,2*i-1-q))
g = risch_integrate(f,x)
ii = g.subs(x,1)
jj = g.subs(x, -1)
if i + k < r:
print s,0
else:
print s,ii-jj[/CODE]
The results are (taking m=4; n =3) : ...
[CODE lang="python" title="stieltjes polynomials"]k = 1
a3 0
a2 6/35
a1 8/63
k = 2
a3 2/7
a2 8/105
a1 4/77[/CODE]
As their article suggested to take the highest coefficient as unity, therefore we multiply a2 and a1 from k=2 by ##7/2##
And using Gauss-Jordan Elimination to find the coefficients:
[CODE lang="python" title="GJ elimination"]a = Matrix([[6.0/35,8.0/63,0],\
[4.0/15,2.0/11,0]])
b = gjmat2(a,2)
pp.pprint(Matrix(b))[/CODE]
and the results are:
[CODE lang="python" title="GJ elimination"]Matrix([
[1.0, 0.740740740740741, 0],
[ 0, -0.015712682379349, 0]])[/CODE]
Thank you for helping me!
  • · Replies 0 ·
