Stokes theorom question with a line
2 replies · 2K views
Austturt
F[/B]=(y + yz- z, 5x+zx, 2y+xy )
use stokes on the line C that intersects: x^2 + y^2 + z^2 = 1 and y=1-x
C is in the direction so that the positive direction in the point (1,0,0) is given by a vector (0,0,1)
2. The attempt at a solution
I was thinking that I could decide my surface Y to be where the plane is cutting the sphere but I'm not sure how to parametrize this or if it's the right way to do it?
You only have to parameterise the line don't you, not the surface?
A natural parameterisation might be to use as parameter the angle ##\theta## that the line from the centre of the circle C to ##\mathbf{x}(\theta)## makes with the x-y plane. It should be doable from there.
If the integration gets too messy you could try rotating the coordinate system by 45 degrees around the z axis so that the circle C has a constant x' coordinate. But I'd leave that as plan B for now.
The limits for ##\theta## given by the curve ##C## would be ##0 \leq t \leq 2 \pi##, where the curve ##C## is the boundary curve of the intersection of ##y = 1 - x## and ##x^2 + y^2 + z^2 = 4##.
Find a parameterization ##\vec r(t)## such that:
$$\iint_S \text{curl}(\vec F) \cdot d \vec S = \oint_C \vec F \cdot d \vec r = \int_0^{2 \pi} \vec F( \vec r(t) ) \cdot \vec r'(t) \space dt$$
Hint: With ##y = 1 - x##, the sphere becomes an elliptic cylinder in the xz-plane: ##x^2 + (1 - x)^2 + z^2 = 4##. The projection of the elliptic cylinder onto the xz-plane produces an ellipse that is not centered at the origin.
