Storing KNO3: Best Practices for Safe Containment
  • Thread starter Thread starter Nimajneb
    chemicals
Storing KNO3 (potassium nitrate) requires careful consideration of containment methods to ensure safety and prevent contamination. Users should avoid using plastic containers that may retain moisture or contaminants, such as old snack containers. Instead, it is recommended to use labeled, airtight containers, ideally with a double-sealed bag inside, and to keep KNO3 in a cool, dry, and well-ventilated area, away from incompatible substances. Proper handling precautions include avoiding ingestion, inhalation of dust, and contact with skin and eyes, as KNO3 can be toxic to various organs.
  • Understanding of KNO3 properties and hazards
  • Knowledge of proper chemical storage practices
  • Familiarity with Material Safety Data Sheets (MSDS)
  • Basic safety protocols for handling chemicals
  • Research best practices for storing hygroscopic chemicals
  • Learn about the NFPA 43A Code for the Storage of Liquid and Solid Oxidizers
  • Investigate the safety measures for handling potassium nitrate in rocket fuel applications
  • Explore suitable container options for chemical storage, such as canning jars and screw-cap bottles
This discussion is beneficial for hobbyists in rocketry, chemistry enthusiasts, and anyone involved in the safe handling and storage of oxidizers like potassium nitrate.
Nimajneb
I just got 2lbs of 99.8% Pure KNO3 Powder in the mail. It came in a kind of sketchy bag. I want to contain somewhere safe, so... where should I put it? Is an old Pretzel Snack plastic container good enough, or do I need a good seal?
Chemistry news on Phys.org
Not a good idea in a kitchen where someone could be surprised.
A pretzel bag will probably have some salt in it. Not likely to stay dry.
You should keep things in labeled containers with MSDS information.
http://www.sciencelab.com/msds.php?msdsId=9927232
Section 7: Handling and Storage
Precautions:
Keep away from heat. Keep away from sources of ignition. Keep away from combustible material.. Do not ingest. Do not
breathe dust. Wear suitable protective clothing. In case of insufficient ventilation, wear suitable respiratory equipment. If
ingested, seek medical advice immediately and show the container or the label. Avoid contact with skin and eyes. Keep away
from incompatibles such as reducing agents, combustible materials, organic materials, metals.
Storage:
Hygroscopic. Keep container tightly closed. Keep container in a cool, well-ventilated area. Separate from acids, alkalies,
reducing agents and combustibles. See NFPA 43A, Code for the Storage of Liquid and Solid Oxidizers.
Likes berkeman
I should have been more specific.
1. It's a kind of barrel-shaped, transparent, plastic container that used to have pretzels in it. (I washed it out.)
2. I'd put it in my room, which has a fan constantly running. I'm not sure if it would be the optimum place, considering that I have a pet bird, and desk made of untreated wood, although I'd only use the KNO3 out of my room for a precaution for my bird.
Why don't you use simply a bottle?
Because I got 2lbs and I don't think it'd fit in a bottle. The plastic-barrel was just laying around so I thought I might as well use that.
Probably, as it doesn't seem to be equally hydrophile as salt. I still would prefer bottles as they can be closed better. Just keep it apart from other chemicals, e.g. boron. May I ask, what you intend to do with it?
Nimajneb said:
2. I'd put it in my room...
The substance may be toxic to blood, kidneys, central nervous system (CNS).
Repeated or prolonged exposure to the substance can produce target organs damage.
I will not recommend have anything with a health warning in your bedroom.
An non-damaged plastic container and lid is as good as the seal. For example canning jars have a "rubber" gasket where the glass contacts the lid. Soda bottle lids usually have an insert in the cap which does the same thing. The water and CO2 do not leave a soda bottle. Water does slowly leak out of most bottle water bottles which are threaded plastic. The leak is not very noticeable on short time scales. The gasket (or seal) cannot be made of anything that reacts with the chemical.
Completely sealing a container is not necessarily safe either. The container could pop.
A plastic bag inside of a solid container is less likely to fail than either one by themselves.
That's exactly what I did. The KNO3 came in a double sealed bag, so I put that inside of the plastic container.
@Nimajneb -- I would like to know the application as well.
Rocket fuel. Sugar as the combustible and KNO3 as the oxidizer.
My cousin and I are having a rocket contest. (P.S. I want to be a Rocket Scientist. Although Sugar Rockets are probably quite far from actual Rocket Science.)
KNO3 isn't wildly hygroscopic, so any big bottle with a screw cap should be fine. If you're really concerned, you can always wrap a layer of parafilm around the opening.
It's not a dangerous or corrosive substance by itself, but could be poisonous if a large amount was consumed.
Any sealed container will do, and kept in a dry cool place is probably a good idea.
What level certification do you have from the Tripoli Rocketry Association?
Isn't it only for high power rockets?
I guess so. It came up in the Mentor discussion about this thread...
NVM if it's not applicable here.
  • · Replies 27 ·
55K
  • · Replies 19 ·
  • · Replies 36 ·
21K
