Straight lines and flat surfaces
birulami
Suppose I have a parameterized line ##\phi:\mathbb{R}\to\mathbb{R}^n## given by ##\phi(t) = (x^\mu(t))|_{\mu=1}^n##. How can I tell that the line is straight.
My best answer so far is that at every time ##t## the acceleration (2nd derivative) is parallel to the velocity (1st derivative), i.e. ##\ddot{\phi}(t) = g(t)\cdot\dot{\phi}(t)##, for some function ##g(t)## (which likely should better not be zero anywhere).
Is this a valid description (necessary and sufficient) of a straight line? Are there different ones?
And a very similar question for a 2-dimensional surface, i.e. now we have ##\phi:\mathbb{R}^2\to\mathbb{R}^n##. Assuming the above is true for the straight line description. Is there a similar condition for the surface?
Since you have posted this in the Differential Geometry forum, this may be a good time to read (up) on geodesics which is the generalization of the idea of "straight line".
If you really mean "straight" rather than "geodesic", a line is straight, at a given point, if and only if its second derivative, with respect to arc length, is 0.
This is correct. A straight line can be parameterized to have the equation c(t) = b + at for vectors a and b. Any path that follows this line will be a reparameterization of it i.e. t = f(s). You can prove your conclusion using the Chain Rule.
The same idea applies for the map of a plane into Euclidean space or for a map of R^m into R^n. The only difference is the number of parameters.
