Is A_θ equal to A_0/cos θ in stress on an oblique plane?
  • Thread starter Thread starter member 392791
    Plane Stress
The discussion confirms that the area A_θ on an oblique plane is indeed equal to A_0/cos θ, where A_0 represents the cross-sectional area of a bar when the cutting plane is perpendicular to its longitudinal axis. The force acting on the cross-section is Pcosθ, and the geometry of the situation supports this relationship. The calculation of A_θ, given dimensions height 'h' and width 'w', validates this conclusion. The participant expresses gratitude to SteamKing for clarifying the concept.
  • Understanding of basic mechanics and stress analysis
  • Familiarity with geometric principles related to angles and areas
  • Knowledge of force components in physics
  • Basic proficiency in calculating areas of geometric shapes
  • Study the derivation of stress on oblique planes in mechanics
  • Learn about the principles of normal and shear stress
  • Explore the application of trigonometric functions in engineering contexts
  • Investigate the implications of cutting plane angles on structural integrity
Students and professionals in engineering, particularly those focused on mechanics, structural analysis, and materials science, will benefit from this discussion.
member 392791
Hello,
I am looking at my lecture notes PDF, and I am having trouble seeing the geometry how A_θ is A_0/cos θ. I can understand how the force acting on that cross section is Pcosθ, just not the part about the area for which F is acting. I think F is normal to the plane, so the cross section area is not just A_0??
I think you must assume that A0 is the cross sectional area of the bar when the cutting plane is normal to the longitudinal axis of the bar.
It's easy to calculate Aθ, assuming A0 has dimensions height 'h' and width 'w' and the cutting plane makes angle θ with the vertical. Try it, and compare Aθ with A0.
Okay, I have convinced myself that A_θ is A_0 / cos θ. I think I have convinced myself of the slide now, Thanks SteamKing
  • · Replies 30 ·
  • · Replies 16 ·
  • · Replies 21 ·
