Stresses and strains in steel sheet
  • Thread starter Thread starter *Alice*
    Steel
This discussion focuses on calculating the stresses and strains in a steel sheet subjected to a 40K temperature change, with specific dimensions and material properties provided. The steel sheet has a thickness of 5mm and is clad with 2mm thick copper layers on both sides. The relevant material properties include Young's modulus (E), Poisson's ratio (v), and the thermal expansion coefficient (alpha) for both steel and copper. The calculated results indicate stresses of 70 N/mm² for steel and 87.5 N/mm² for copper, with corresponding strains of 0.673 millistrain for steel and 0.24 millistrain for copper.
  • Understanding of thermal expansion coefficients (alpha) for materials
  • Knowledge of Young's modulus (E) and Poisson's ratio (v)
  • Familiarity with stress-strain relationships in materials
  • Basic principles of composite materials and their behavior under thermal loads
  • Study the calculation of thermal stresses in composite materials
  • Learn about the finite element method (FEM) for stress analysis
  • Research the effects of temperature changes on material properties
  • Explore advanced topics in material science related to thermal expansion
Engineers, material scientists, and students involved in mechanical design, particularly those working with thermal effects on composite materials.
*Alice*
Dear all, I am trying to calculate the stresses and strains induced by a 40K change in temperature of a steel sheet of thickness 5mm, that is clad on both sides with 2mm thick layers of copper. For both materials E, alpha (í.e. the thermal expansion coefficient), as well as v (Poissons ratio are given).
My attempt was equating the forces (see attached word document).
This does unfortunately not work and the fact that the Poisson ratios are given makes me think that I have missed something out. Can anyone help?
Thanks a million for any help, hints and suggestions.
Alice
I do not see why the temperature change would induce a stress in the specimen as it is free to expand? Could you provide the full question?
where is the geometry?
The questions says:
A steel sheet of thickness 5cm is clad on both sides with 2mm thick layers
of copper. Determine the stresses and strains induces by a 40K change in
Temperature
given Data:
for steel: E=210kN/mm^2, v=0.3 (Poissons ratio), alpha=11*10^(-6) 1/K
for copper: E =180 kN/mm^2, v=0.35, aplpha = 30*10^(-6) 1/K
Solution: 70 N/mm^2, 87.5N/mm^2, 0.673 millistrain, 0.24millistrain, 1.77
millistrain
I thought there was geometry, since the steel is clad on top and bottom with 2mm thick layers of copper.
  • · Replies 16 ·
