Stresses on penstock supported by ring girder
  • Thread starter Thread starter Zohra
    Ring
The discussion focuses on the stresses experienced by penstocks supported by ring girder legs, specifically addressing the lack of dimensional guidance in ASME standards for support legs. Participants highlight that while the dimensions of the support legs may influence stress calculations, the overall load on the supports remains relatively unchanged. Additionally, bending moments in the penstock may require more critical attention than the loads on the supports. The conversation emphasizes the need for clarity in numerical analysis and CAD modeling of penstocks.
  • Understanding of ASME standards related to structural engineering
  • Knowledge of stress analysis in penstocks and ring girders
  • Familiarity with CAD software for numerical analysis
  • Basic principles of bending moments and structural deformation
  • Research ASME standards for structural supports and their implications on stress calculations
  • Explore methods for calculating bending moments in penstocks
  • Learn advanced CAD techniques for modeling structural supports in numerical analysis
  • Investigate the effects of temperature, snow/ice loading, and geological factors on penstock performance
Structural engineers, civil engineers, and professionals involved in the design and analysis of penstocks and dam structures will benefit from this discussion.
Zohra
the penstocks are either supported on the saddles or on ring girder legs. the standards ( like ASME) make the calculation of the stresses on the ring girder without giving the dimension of the support leg , whereas I think that the change of the dimensions of the leg will probably change the stresses on penstock and ring . can someone enlighten me on this point please ?
To question the rationale and assumptions of ASME codes, you need to ask the ASME committee members. That's very difficult.
But you too did not give the dimensions of the support legs, so how can you conclude that they will change dimensions?
It may also be true that other places in the ASME standards cover supports and overall calculation strategy.
I had second and third thoughts on your penstock question.
2. If the supports compress a small amount, the penstock will simply bend and the load on the supports won't change much. Bending moments in the penstock could become a more critical calculation than loads on the supports.
3. Deformation of the supports may be small compared to sag of the penstock at high temperatures, or snow/ice loading, or ground settling, or geological deformations in the bedrock over the life of the dam.
yes I was not clear in my question, I meant that standards have given formulas that calculate the stresses on the ring girder without taking into account the dimensions of leg. I want to make a CAD of the penstock to do numerical analysis and I do not know which length to give to the leg to meet the results given by the formulas. But since the load on the supports wont't change much so so no matter their size thank you so much ! maybe I have to remove the legs from the CAD for the numerical analysis and model the legs only by a fixed point ? Thank you for your support
(it is translated from french so sorry for the errors )
  • · Replies 22 ·
