How Do You Calculate the Meeting Point of Two Stones Thrown from a Cliff?
The problem involves calculating the meeting point of two stones thrown from a cliff of height 6.00 meters, one upwards and the other downwards, both at an initial speed of 9.0 m/s. The correct approach requires formulating two separate equations for the heights of each stone as functions of time, identifying the specific time (tc) when both stones are at the same height. The equation x = (Vo)(t) + 1/2(a)(t^2) is applicable, with acceleration due to gravity set at -9.8 m/s². This method leads to determining the height at which the stones cross paths.
  • Understanding of kinematic equations in physics
  • Knowledge of free-fall motion and gravitational acceleration
  • Ability to solve quadratic equations
  • Familiarity with the concept of relative motion
  • Study the derivation and application of kinematic equations for projectile motion
  • Learn how to set up and solve simultaneous equations in physics problems
  • Explore the concept of relative velocity in free-fall scenarios
  • Practice solving problems involving two objects in motion with different initial conditions
Students studying physics, particularly those focusing on kinematics and motion, as well as educators looking for examples of free-fall problems involving multiple objects.
Jordan Jones
Two stones are thrown simultaneously, one straight upward from the base of a cliff and the other straight downward from the top of the cliff. The height of the cliff is 6.00m. The stones are thrown with the same speed of 9.0m/s. Find the location (above the base of the cliff) of the point where the stones cross paths.
x = 6 m
Vf = 9 m/s
a = -9.8 m/s2 (i think?)
x = (Vo)(t) + 1/2(a)(t^2) or
Vf^2 = Vo + 2(a)(x) maybe?
I was thinking about using x = (Vo)(t) + 1/2(a)(t^2) but it's not working and I can't tell if I'm not using it correctly or it's just not the right equation.
6 = (0 m/s)(t) + 1/2(-9.8m/s^2)(t^2)
-1.22 = t^2
This obviously isn't going in the right direction.
Could anyone help me get started? I've understood most of the other free-fall problems in my book but the logic or strategy needed here is really confusing me.
This is the right equation to use, but you need to write two separate equations giving the height of each stone above ground at any time t. Then you need to say that there is a specific time tc at which the stones are at the same height. Solve for the time tc and then use it in either equation to find the desired height.
