Stuck integral (electric potential)
The discussion revolves around calculating electric potentials through integration over a charge distribution, specifically for a surface with a uniform charge distribution bounded by two planes. The integral in question involves the distance between points in the charge distribution and a field point outside the surface.
  • Exploratory, Assumption checking
  • Participants are exploring how to approach the calculation of the integral given the specific geometry of the surface and the conditions of the problem. There are questions about the precise definition of the surface involved.
Some participants have pointed out the need for more precise specifications regarding the surface in question. The original poster has clarified that the surface is assumed to be of infinite extent and represents a part of ventricular tissue separated by two walls.
There are constraints regarding the information provided, particularly about the surface's characteristics and the implications of the geometry on the integral calculation.
Carl140
When one calculates electric potentials, it involves integrating over the charge distribution, and for a surface with a uniform charge distribution, you encounter an integral of the form:
[tex]\int_{\mathcal{S}} \frac{d^2x'}{|\vec{x}-\vec{x'}|}[/tex]
Where [itex]\vec{x}[/itex] is the vector from the origin (in whatever coordinate system you choose) to the field point (the point at which you want to determine the potential), [itex]\vec{x'}[/itex] is the vector from the origin to a point on the surface containing the charge distribution, and the integration is over the source points.
Now I want to calculate this integral but in the following situation:
Here S is a surface which is bounded by two planes.
Here's a picture which illustrates the situation:
http://www.ccbm.jhu.edu/doc/presenta...sisDefense.pdf
Page 41, picture D. You can see the two planes I was referring two. Here "S" is the surface which is exactly in the middle. Now x is a point OUTSIDE of S and x' is a point in S (of course at least one of them must be outside S otherwise the denominator is not defined).
How can you approach this calculation?
Your link doesn't work.
Sorry. Here it is:
After /doc it should be /presentations/pdf/ScollanThesisDefense.pdf
That is: /doc/presentations/pdf/ScollanThesisDefense.pdf
It is working, just checked it.
You have to specify what the surface is more precisely.
That's all I'm given, I forgot to state that also S is assumed to be of infinite extent, basically S represents a part of the ventricular tissue which is separated by two walls: the epicardium and the endocardium.
