Understanding First Order ODEs and Intersection of Curves
  • Thread starter Thread starter ka_reem13
    Ode Stuck
This discussion focuses on solving first-order ordinary differential equations (ODEs) and the intersection of curves. The primary equation discussed is the rearrangement of the ODE to express the perimeter p as dy/dx, leading to the relationship dp/dx = p/x. The conversation also addresses the intersection of two lines and the calculation of the angle between them using the formula for cos θ, particularly when the lines intersect at right angles. The participants express confusion regarding the derivation of additional curves and the real roots of the quadratic ODE.
  • Understanding of first-order ordinary differential equations (ODEs)
  • Familiarity with quadratic equations and their roots
  • Knowledge of calculus, specifically differentiation and tangent lines
  • Basic trigonometry, particularly the cosine of angles between lines
  • Explore the method of solving first-order ODEs using separation of variables
  • Investigate the properties of quadratic equations and their discriminants
  • Learn about the geometric interpretation of ODE solutions and their integral curves
  • Study the application of trigonometric identities in determining angles between curves
Students and professionals in mathematics, particularly those studying differential equations, calculus, and geometry. This discussion is beneficial for anyone looking to deepen their understanding of ODEs and the intersection of curves.
ka_reem13
(a) Solve the differential equation:
[x * (dy/dx)^2] - [2y*(dy/dx)] - x = 0
How many integral curves pass through each point of the (x,y) plane (except x = 0)?
why is the solution at each point not unique
(b) The differential equation:
[(dy/dx)^2] + [f(x,y)*(dy/dx)] - 1 = 0
represents a set of curves such that two curves pass through any given point. Show that these curves intersect at right angles at the point. at f = -2y/x verify this property for the point (3,4)
I'm aware that I can introduce the perimeter p = dy/dx
then I can rearrange my equation to make y the subject, then I can show that dp/dx = p/x. However, this only gives me a bunch of quadratic curves for my solution. However given part b I see that two curves are meant to intersect each point and I don't know where I'll get the second set of curves (solutions) from.
for part b honestly I don't even know where to start
(a) The ODE is a quadratic in \dfrac{dy}{dx}. How many real roots does it have?
(b) If two lines y = m_1x + c_1 and y = m_2x + c_2 intersect, then the angle between them at the intersection is given by \cos \theta = \frac{(1,m_1)\cdot(1,m_2)}{\|(1,m_1)\|\|(1_,m_2)\|} = \frac{1 + m_1m_2}{\sqrt{1 + m_1^2}\sqrt{1 + m_2^2}}. What is \cos \theta if the lines intersect at right angles? To apply this to two curves, one looks at the tangent lines at the point of intersection. What are the gradients of these tangent lines if the curves are the integral curves of this ODE?
parameter
You can? I don’t see how. Please post your working.
Easy, just cancel the d's. :oldbiggrin:
$$\frac{dp}{dx} = \frac{\cancel dp}{\cancel dx}$$
  • · Replies 18 ·
