Study on ruled vs unruled paper?
  • Thread starter John Mcrain
    Paper Study
52 replies · 12K views · last reply
John Mcrain
Why all scientists write math/physics on blank paper, for example Einstein,in that time already exist lined/cell papers?
Is there any benefits to use blank paper notebooks when study engineering?
What notebooks do you use when study math/physics/engineering?
I use ruled notebook paper usually. It's simply what I've always had and I find the lines make it easier to keep all of my writing organized.
You do math at paper with lines, isnt better on cells?
Some incorrect or misleading ideas there. One writes on the kind of paper one is comfortable with; or in some cases, one writes on the style of paper which the administration requires. My own choice is to use white, unlined paper for most writing, but to try to use professionally prepared graph paper to make graphs.
How you mean, "cells"? In some situations, one can construct tabulation slots, but each of these tables would be drawn only when needed or desired, and on normally unlined paper. (or on lined paper, if the person prefers this.)
John Mcrain said:
Why all scientists write math/physics on blank paper ... ?
ALL? Do you have any evidence for that categorical statement or is this more along the lines of "according to a statistic that I just made up ... " ?
Sheet of white graph paper with thin blue grid lines forming small square cells across the full page.
I mean most..
I understand that Newton wrote at blank paper because at that time ruled paper didnt exist, but in 20century they eixist,so wonder why Einstein do math at blank paper.
All engineering notebooks have grid papers, usualy math/physisc/engineering use grid paper for writing.
What type of notebook do you use for engineering?
Handwritten mathematical working on unruled cream paper held in a dark frame, with equations and numerical calculations written in columns and some lines of text.
What do you think about engineering paper, one side blank other with grid, so you can still write stright at blank side?
Sorry, but I don't understand the significance of this thread. Why should anyone care what kind of paper other people use?
John Mcrain said:
... Is there any benefits to use blank paper notebooks when study engineering?
Before computers appeared, engineers must take hand drawing classes, and become proficient at it.
All engineering drawings and its texts were done by hand and on paper.
For other people to understand those documents, and to make its presentation uniform, certain sets of rules, formats and limitations were established.
Engineers at that time were encouraged to practice hand control as much as possible.
For that reason, we avoided ruled paper, even for taking class notes or for casual hand sketches.
We were expected to draw a close to perfect straight line, an ellipse and a circle without the help of any instrument.
At least in the country in which I studied, and at that time, lines or grids were considered back then as crutches that could ruin engineer's hand drawing and writing proficiency.
I took 2 years of mechanical drawing. I was terrible at it; partially because I'm left handed. But fortunately, proficiency was never a requirement for engineers, we could hire draftsmen to do the drawings.
  • Wow
It is interesting or frustrating or important to him. He has some experiences and made some observations. Several of the details he did not include. So far the topic is working.
My question about "cells" on paper was because rectangular cells can also be drawn on paper to be filled with tabulated information or data. These can be square-based, or rectangle-based. Drawing them is not difficult, and we do not need graph paper or any kind of lined paper to be able to produce them.
You had to calculate math tasks at blank paper as well? What years was it?
I want to know if there is some engineering rules, because I saw all engineering notebooks has grid paper.
In same time I would like to write on blank paper but my writing is terrible at blank paper.. Words float and sentecese are not straight..
I think you learn easier when contest on paper is nice and clear, so that stops me to use blank paper..
Then what's the problem? Do that. Nobody cares. The trick is not to use the right paper, it's to do the work correctly.
I love past and if engineers use blank paper I will force myself to learn...
Do it neatly, so it can be seen to be correct.
Remember, you are generating evidence that may be used to assist the coroner later.
  • Haha
Here's a digression that ends in a tip for those documenting their work via handwritten notes or calculations.
When I finished school and started working, we (in engineering) wrote our calculations by hand. We often used pre-printed "calc pads" that had the company name and some typical fields for things like calc number, date, page __ of ___ etc. Completed calculations were stored in file cabinets.
In the late 1980s and during the 1990s, these completed calcs were scanned for electronic storage and retrieval. The scanner took an image of each page to create a .pdf file. The scanner margins were normally a bit smaller than the standard 8 1/2 by 11 inch calc pad paper. Frugal engineers tended to write smaller and smaller, and closer and closer to the bottom of the page, when they felt they could complete work on the final page, without starting a new page in the pad. So, the culmination of the calc would sometimes be written in a small hand, at the very bottom of the final page. In the scanned version, then, you see the calculation progressing to its climax: "... and therefore the maximum calculated pressure in the vessel is found to be"
with the following line off the bottom of the scan.
So the tip: do not be frugal with your paper. The final result of the calculation is worth a lot more than the 2 cents one additional page costs the company.
  • Haha
I like that story. Once on an airplane, the stewardess stopped the film and put away the gear when there was still 60 seconds to go in the plot. The film was, "The Sting."
What kind of paper the students use depends on what the head in the departments require. I am guessing you have reported what you have seen.
Some of us or should I say maybe, many of us are able to write in clear horizontal lines on plain unlined paper;; maybe this was just a matter of concentrated practice.
I did not have to, but I have always found ruled paper somehow restrictive of my freedom to locate notes, formulae, calculations, etc.
Therefore, I always used blank paper, while several of my classmates had no problem using other types of papers.
My years of taking technical drafting were 1979 through 1981.
Having a good eraser that left minimum mess behind was the key to good grades.
We studied by this excellent book:
That practice has served me well during many years, while trying to explain an engineering idea to a technician on the field, while having nothing at hand than pencil and paper.
Please, see this article:
https://civilseek.com/free-hand-sketching/
Technical drawing from a Spanish drafting textbook, Fig. II, 175, showing a conical part with dimensioned views, section A-A, and a lathe point below labelled Fig. II, 176 with taper 1:20 and a 60 degree angle.
Hands holding a green pencil over a technical drawing sheet with a semicircular gear-like part, dimensions such as 400±0.1 and Ø180, a protractor, and a yellow tape measure at left.
Today all engineering notebooks have grip papers.
I think doing math/physics on blank paper is Ok only if you write nice.
Do exist maybe some template with grid you can put under blank paper, so you can write straight and nice?
This will require that your paper be thin which can also cause problems.
You are under the misperception that there is a correct answer to your question. At best, there is a correct answer for you. Einstein would still have been Einstein even if he used an engineering pad.
Practice make perfect.
If you want to improve the way others graphically understand your ideas in the future, you can find the best techniques that work for you to practice.
For example, take a piece of blank paper and draw several lines as straight and parallel among them as possible.
It would look bad the first time, but you will sure improve over time.
Rather than looking closely to the point of contact between pencil or pen and paper, keep your focal point on the imaginary ideal location of the end of your horizontal line.
Photo of a Dietzgen SelectaScale Professional Drafting Pad on a upholstered surface, showing a hand holding a pencil and a scale ruler, with grid sample diagrams and the text 8 1/2 x 11, 50 sheets, durable vellum.
