Stupidity at its peak find the mass
  • Thread starter Thread starter flyingpig
    Mass Peak
17 replies · 3K views
flyingpig
A spring is hung from a ceiling, and an object attached to its lower end stretches the spring by a distance of 5.00 cm from its unstretched position when the system is in equilibrium. If the spring constant is 43.2 N/m, determine the mass of the object.
(answer in kg)
[tex]\sum W = \Delta K[/tex]
[tex]mg\Delta y - \frac{k}{2}(y^2) = 0[/tex]
[tex]ky = 2mg[/tex]
I will stop here because this is wrong.
Apparently using Newton's forces
kx = mg
There is no 2...
The object is equilibrium, so the net force on it is ??
ehild
0!
Why am I wrong though? That's what I want to know.
And what forces act on the object?
ehild
Spring and the mysterious force that's pulling it down that is also equal to the (positive) work done by gravity
I start to understand you. It does not matter, how the object is brought to equilibrium. Maybe, you hold the object and let it move very slowly till it reaches equilibrium. Then the net work, yours and that of the spring and that of gravity is zero and you do not reach anywhere. You need to calculate with the forces. So what forces act on the object, hanging at the end of the spring when it does not move any more?
ehild
Well it went down, oh wait it i just gravity. Not so mysterious now...
Yeah and I added them, but it didn't give the same answer as Newton's forces?
What are Newton's forces, and what did you get for the result?
ehild
Well, is not this the same as saying that kx force acts up and mg down, so the resultant force is kx-mg and it is zero as the object is in rest? So what is the mass of the object?
ehild
kx = mg
m = kx/g
But I still don't understand why I am wrong I thought I did it correctly.
It is wrong as the spring never reaches equilibrium if only the spring force and mg act on it. When the object connected to the unstretched spring and released it will oscillate around the equilibrium point, with the distance x=mg/k below the initial position. Its KE is maximum here, insted of zero as you assumed. Try to write Newton's second law for the acceleration and solve the differential equation for x.
ehild
Is the question suggesting we take a particular instant then when you say it keeps oscillating back and forth? Why can't we take the work done at a particlular instant here?
The question states equilibrium.
Being in equilibrium means rest; zero velocity, zero acceleration, zero net force. An oscillating object is not in equilibrium.
When the object is released after attached to the end of the unstretched spring, the spring will stretch by ΔL=2mg/k when the velocity of the object is zero again. At that instant, an upward force F=mg acts on the object. The acceleration is upward, the object moves upward. At ΔL=mg/k, the net force is zero, but the object has velocity, so it will move upward further, till ΔL=0, where the force is downward: The object will oscillate between ΔL=0 and ΔL=2mg/k.
ehild
