Making 't' the Subject of a Formula: Quick and Easy Tips
  • Thread starter Thread starter DerekBrown
    Formula
The discussion centers on the process of making 't' the subject of the formula given as √(3/(S+4)) = -3t. Participants emphasize the importance of correctly applying algebraic principles, particularly the BIDMUS/BODMAS rules, to isolate 't'. The correct transformation of the equation is t = √(3/(S+4)) / -3, highlighting the necessity of proper bracket usage to avoid errors. The conversation also touches on the significance of foundational algebra skills in solving such equations.
  • Understanding of algebraic manipulation
  • Familiarity with BIDMUS/BODMAS rules
  • Basic knowledge of square roots and fractions
  • Ability to work with equations involving variables
  • Study algebraic manipulation techniques for isolating variables
  • Learn more about BIDMUS/BODMAS rules and their applications
  • Practice solving equations with square roots and fractions
  • Explore resources on common algebraic mistakes and how to avoid them
Students struggling with algebra, educators teaching basic algebra concepts, and anyone looking to improve their mathematical problem-solving skills.
DerekBrown
I've currently got a quick and short question about making something the subject of the formula. I've managed to do most of it myself, I'm just stuck on the last bit.
Here is a picture of what I've got so far, how do I make 't' the subject of the formula?
Here is a picture of the formula: http://puu.sh/7chNU.jpg
Thanks!
Show your effort first.PF rules requires it.
btw,This is a homeWork question
These are my efforts, there were two equations and I made them into one. I just need assistance on how I should take the -3 over onto the other side. It's a simple question that requires a one answer response really.
What's this "subject of the formula"? I've never heard of such a thing.. Is it isolating the ##t## in the equation?
Yes, we are trying to make 't' the subject of the formula by moving everything onto the other side. I've managed to move every other equation onto the other side, but I'm stuck on how to move the -3 over and where it'll end up at.
To make things easier,Let's convert the Question to LaTeX,
##\sqrt\frac{3}{S+4}=-3t##
Simply move it.That's all.
For example,
y=-3t
What will you do here?
I understand that we have to divide by -3 to move it onto the other side, but I don't exactly know where it'll then end up once we've done so, that's the issue I have.
What?
In my above example,
##y=-3t##
so ##t=\frac{y}{-3}##
Do the same for your equation
If I do the same as your example it'll be:
√(3/S+4-3) = t - Was it that simple?
That's wrong.
Show your steps,to see where you went wrong.
Basically you stated that y = -3t, so when we divide the -3 from t it'll equal y/-3 = t.
That's what I attempted to do with the formula above, unless it'll go out from the square root and equal:
√(3/S+4) / -3
That's the only other solution I can think of.
Neither had I! A Google search shows that it's apparently a British English expression. In American English we usually say something like "solve the equation for t" or "isolate t".
Yes, that's it. If you move it inside the square root you have to square it: ##3 = \sqrt{3^2} = \sqrt{9}##.
√(3/S+4) / -3
Are these two answers the same?
BTW,The two answers are is wrong.Do you know why?
It's because you used brackets in the wrong way.
Use brackets in the correct way and post the answer.
Sorry I am not able to give the direct answer because PF rules are against it. :redface:
I'm going to be honest here, I've stumped and I have no clue what to do.
The only other way I can think of is:
√((3/S+4) / -3)
Double post...
√((3/S+4) / -3)
The original question was this:
##\sqrt{\frac{3}{s+4}}=-3t##
Move -3 to right side.and this gives:
Simple... :wink:
So this way, √((3/S+4) / -3), was the correct way?
DerekBrown, in what grade are you? You should probably ask your teacher for help because basic algebra is absolutely needed in every single math/physics course you'll take in your life.
No, that is not the correct way.
Using adjacent's equation (you'll be remembered adjacent!) ##y=-3t##, you know that ##t=y/(-3)##. Now, what happens if ##y## equals the left side of your original equation?
*sigh*
That gives ##\sqrt{\frac{\frac{3}{S}+4}{-3}}##
You know it's wrong,don't you?
According to BIDMUS or BODMUS(or whatever)
You have to divide before adding so 3/s is divided first.But the correct way is,S+4 add first.That's where brackets come into play.Brackets are always executed first.B is brackets in BIDMUS rule
First write in hand then Use BIDMUS rule and use brackets the correct way.You'll get incorrect results if you are not careful with brackets.
haha.That equation will become more famous than ##E=mc^2## . :devil:
If I'm going to be insulted for being confused on these forums then forget it, I'll take my questions else where mmf. Thank you for your assistance mmf.
Just follow BIDMUS rule.
Anyway,since you are only confused about the brackets,this is the correct answer:
##\frac{\sqrt{\frac{3}{s+4}}}{-3}=t##
Now check the differences between your answer(with bracket problem) with this.
This can be written as:
(√(3/(s+4)))/(-3)=t
See how the brackets are used.
I didn't insult you. If you think that telling you to ask a professor for assistance is insulting you, then I believe you're really short tempered.
I didn't mean to say it in a condescending way.. I really think that you should solidify your algebra, and a good way to do that is by having someone with you, face to face, to teach you. Algebra is absolutely necessary.
But hey, whatever works for you.
