Submarine Torpedo Momentum Question: Solving for Velocity Change
  • Thread starter Thread starter ppl k1ll3r
    Momentum
The discussion focuses on the momentum calculation of a submarine firing a torpedo. A 60-tonne submarine traveling at 1.5 m/s fires a 500 kg torpedo at 21 m/s relative to itself, resulting in a final submarine velocity of 1.3 m/s forward. The correct momentum equations were established, confirming that the torpedo's speed should be considered as 22.5 m/s when accounting for the submarine's initial velocity. Participants clarified the importance of sign conventions in momentum calculations, emphasizing that while the submarine experiences a change in momentum, its final velocity remains positive.
  • Understanding of momentum conservation principles
  • Basic knowledge of physics equations involving mass and velocity
  • Familiarity with vector addition in physics
  • Ability to interpret relative velocities
  • Study the concept of momentum conservation in closed systems
  • Learn about vector addition and its application in physics problems
  • Explore examples of relative velocity in motion scenarios
  • Review the implications of sign conventions in physics equations
Students studying physics, particularly those focusing on mechanics and momentum, as well as educators seeking to clarify concepts related to momentum conservation and relative motion.
ppl k1ll3r
A 60 tonne submarine, intially traveling forward at 1.5 m/s, fires a 500 kg torpedo striaght ahead with a velocity of 21 m/s in relation to the submarine. What is the velocity of the submarine after it fires the torpedo?
Answer: 1.3 m/s [forward]
1 ton = 1000 kg
p = p'
p = p'
(60000)(1.5) = (500)(22.5) - (59500)(Vs')
Vs' = -1.32 m/s
I don't understand why I am getting that answer, as the answer is actually forward. Because doesn't the torpedo going forwards cause the submarine to move backwards.
Other than that, can you guys tell me whether I set it up right? Like the speed of the torpedo should be 22.5 m/s right, since the submarine is already traveling at 1.5 so it gets added? Also, the final mass of submarine shud be 59 500 kg, since the torpedo is no longer attached to it?
Thanks.
Anyone!?
Why do you have a minus sign?
p = mv
p_{sub_i} = p_{sub_f} + p_{torpedo}
60000 \times 1.5 = (59500 \times v_{sub_f}) + (500 \times 21)
v_{sub_f} = (60000 \times 1.5) - (500 \times 21) = 1.336
Forgive the lack of units.
p = mv
Minus because the momentum of the torpedo being shot forward causes the sub to move back. Also, shouldn't the torpedo have a speed of 22.5 m/s, since its 21 m/s relative to the sub, so it has a speed of 22.5? Like say if you're running at 2m/s and you throw a tennis ball at 5 m/s, the speed of the tennis ball would be 5 relative to you, but 7 m/s in total.
momentum of before = momentum of after
(60000)(1.5)=(59500)v+(500*22.5)
Yes, its 22.5. But there's no negative sign since their both doing in forward (Same direction.).
To avoid confusion with signs in the future, define a direction to be positive, then always use positive signs in the momentum equations (ex. m1v1=m2v2 + m3v3). Get the signs of the velocities correct and the sign of the final answer will be correct.
You are confusing change in momentum with final momentum. Yes indeed the CHANGE in the sub's momentum is in the negative dirrection. However, the final momentum for the ship is still in the positive direction.
  • · Replies 16 ·
  • · Replies 19 ·
