Substitute, simplify, and then solve for Z
  • Thread starter Thread starter Addez123
    Simplify
The discussion focuses on solving the differential equation for the variable z by substitution and integration. The correct approach involves recognizing that z_u equals zero, leading to the integration of z_u rather than z_v. The solution is expressed as z = g(v), where g(v) can take the form g(1/x - y) = z(x,y). Boundary conditions, such as z(x,0) = h(x), are essential for fully specifying the function.
  • Understanding of differential equations
  • Familiarity with integration techniques
  • Knowledge of boundary conditions in mathematical functions
  • Basic concepts of multivariable calculus
  • Study methods for solving differential equations
  • Learn about boundary value problems and their applications
  • Explore integration techniques for multivariable functions
  • Investigate the implications of different boundary conditions on solutions
Mathematicians, physics students, and anyone involved in solving differential equations or studying multivariable calculus will benefit from this discussion.
Addez123
Simplify the equation
$$x^2 z_x - z_y = 0, x > 0$$
using the variable change u and v.
Then solve the differential equation.
$$u = x$$
$$v = 1/x - y$$
By substitution I've solved that $$z_u = 0$$ (which is correct according to textbook)
which leads me to try find z by integrating
$$z = \int z_v \,(dv ?)$$
and I'm just stuck here. Dont know how to integrate that.
It is not ##z_v## you should integrate (you do not have an expression for it), it is ##z_u##.
So $$z = \int z_u \,du = \int 0 \,du = g(v)$$
Doing this and I havn't really solved anything.
Yes you have. Any (differentiable) function on the form ##g(v) = g(1/x - y) = z(x,y)## solves the differential equation. You can never fully specify the function without boundary conditions. For example, in this case, a possible boundary condition could be ##z(x,0) = h(x)##, where ##h## is some known function, which would identify ##g(1/x) = h(x)## and therefore ##z(x,y) = h(1/(1/x-y))##.
It did turnout that g(v) was the correct solution :P
Thanks!
  • · Replies 16 ·
