What Happens When Sulfur Reacts with Copper and Tin at High Temperatures?
The discussion centers on the reaction between sulfur, copper, and tin at high temperatures, specifically at 1000K in a nitrogen atmosphere to prevent oxidation. The primary reactions identified are Cu + S = CuS and Sn + S = SnS, with an emphasis on the molar basis of reactants. The participant expresses concern about excess sulfur (250g) potentially leading to sulfur vapor formation, which could damage the equipment. The complexity of the reaction is highlighted by the formation of various copper sulfides (CuxSy) and tin sulfides (SnxSy), necessitating the use of thermodynamic databases for accurate calculations.
  • Understanding of stoichiometry and molar calculations
  • Familiarity with sulfur chemistry and its reactions
  • Knowledge of thermodynamics and reaction energetics
  • Experience with high-temperature reaction setups and safety protocols
  • Research thermodynamic databases for reaction energy calculations
  • Study the formation of copper and tin sulfides in detail
  • Learn about high-temperature reaction kinetics and mechanisms
  • Explore literature on sulfur chemistry and process engineering
Chemists, materials scientists, and process engineers interested in high-temperature reactions involving sulfur, copper, and tin, as well as those looking to optimize reaction conditions and safety in laboratory settings.
sundriedtomato
Dear all
I have 250g of Copper 250g of Tin and 250g of Sulfur.
Everything is in powdered form.
Heated up in closed container wit surrounding nitrogen flow to avoid contact with Oxygen.
Heating ramp is 3 hours to 1000K.
What reaction will be the leading reaction?
How to calculate how fast will S react with Metals and at what temperatures?
If there is excess of sulfur - in what form will it leave the vessel - S4, S8?
I am afraid that there will be huge formation of sulfur vapor and it can damage the oven and everything else.
I am still searching for a good book on Sulfur Chemistry and process engineering. If there is a good literature - please advise.
Has one tried writing the thermodynamic equations?
Cu + S = CuS
Sn + S = SnS
Also, one should apply on molar basis rather than mass.
250 gm of S is likely an excess of S. 250 g of S, would be about 7.8 moles.
250 gm of copper is about 3.9 moles Cu, 250 gm of tin is about 2.1 moles Sn.
Whatever their source, copper sulfides vary widely in composition with 0.5 ≤ Cu/S ≤ 2, including numerous non-stoichiometric compounds.
http://en.wikipedia.org/wiki/Copper_sulfide
So the next step would be to use thermodynamic databases to find values and calculate reaction energies? Will try that.
The trick is as Astronuc mentioned is that there are a lot of possibilities for CuxSy and SnxSy binaries formation. And it is quite hard to pinpoint the right amount of S for everything to go into the right side of euqtion. There is constantly increasing temperature, that should guide the process.
Rephrasing the question:
If I have slightly less S in the system - will ~3 hours be enough time for metals and sulfur to react?
  • · Replies 19 ·
9K
60K
