What is the Simplified Sum of Partial Derivatives for a Homogenous Function?
The discussion centers on proving the equation x∂²z/∂x² + y∂²z/∂y∂x = 2∂z/∂x for the function z = x²y²/(x+y). A participant successfully derived the correct answer using a lengthy method but expressed confusion over the teacher's more efficient solution, which involved recognizing z as a homogeneous function of degree 3 and applying Euler's homogeneous function theorem. The key takeaway is the use of operator interchange and the properties of homogeneous functions to simplify the derivation. Despite the participant's uncertainty about the relevance of homogeneous functions for exams, they acknowledge the value of this technique. Understanding these concepts can enhance problem-solving skills in calculus.
Mr.Rockwater
I need to prove that x\frac{ \partial^2z}{ \partial x^2} + y\frac{\partial^2z}{\partial y\partial x} = 2\frac{\partial z}{\partial x}
z = \frac{x^2y^2}{x+y}
I actually did it the long way and I got the right answer but here is my teacher's solution :
\Rightarrow x\frac{ \partial z}{ \partial x} + y\frac{ \partial z}{ \partial x} = 3\frac{ \partial z}{ \partial x}
\Rightarrow \frac{ \partial z}{ \partial x} +x\frac{ \partial^2z}{ \partial x^2} + y\frac{ \partial z}{ \partial x} = 3\frac{ \partial z}{ \partial x}
Answer follows.
To be honest, I have absolutely no idea about what technique he actually uses there. Is there any "rule" or "trick" that I am not aware of here?
It follows from observing z is homogeneous of degree 3, Euler's homogeneous function theorem, and interchanging operators.
x zxx+y zyx=(x zx+y zy-z)x
by commuting operators
=(3-1)zx=2zx
by Euler's homogeneous function theorem
thus
zx is homogeneous of degree 2
or we could go backwards and just show zx is homogeneous of degree 2
Thank you! Our teacher didn't ever mention homogenous functions though, I assume this ain't going to be in the exam. At least I'll have that tool in my arsenal :-p
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
