Sum of Series in |z| < 1: Sin(\frac{2\pi}{3})+z
  • Thread starter Thread starter FanofAFan
    Series Sum
The discussion revolves around finding the sum of a series involving sine functions and complex variables, specifically within the context of the unit disk defined by |z| < 1. The series presented includes terms like sin(2π/3) + z sin(4π/3) + z² sin(6π/3) and continues in a similar pattern.
  • Participants explore the nature of the series and consider separating it into real and imaginary components. There are questions about the sum of the series and its relation to geometric series, with some uncertainty about the starting point for solving the problem.
Participants are actively engaging with the problem, with some offering hints and suggestions regarding the geometric series. There is a mix of interpretations and approaches being discussed, but no consensus has been reached on the solution yet.
Some participants express confusion about the initial steps and the transformation of the series, indicating a need for clarification on the series' properties and convergence criteria.
FanofAFan
Find the sum in |z| < 1 of the series sin([tex]\frac{2\pi}{3}[/tex]) + z sin([tex]\frac{4\pi}{3}[/tex]) + z2 sin([tex]\frac{6\pi}{3}[/tex]) + ... + zk sin(k[tex]\frac{2\pi}{3}[/tex]) + ...
[tex]\sum[/tex] n =1 to [tex]\infty[/tex] (e2pi*i/3z)n = 1 + [tex]\sum[/tex] n =1 to [tex]\infty[/tex] (e2pi*i/3z)n
What's the question and where's your attempt at solving it?
Not sure where to begin, thought I'd get some type of hint, but I figured let z = x +iy and change the series to sin(2pi/3) + x sin(4pi/3) + iy sin(4pi/3) + x2 sin(6pi/3) - y2 sin(6pi/3) + 2ixy sin(6pi/3) +...+ and maybe separate the series in real and imaginary parts, I'm completely off
Do you know what the sum of the series you listed in the relevant equations section is?
Si
it is 1+e2pi*i/3z + e4pi*i/3z2 + e6pi*i/3z3 + .. + ek(2pi*i/3)zk
I meant, do you know what it sums to? Hint: It's a geometric series.
Is it Maclaurin series for exponental... so 1 + e^(2i pi/3) z = cos(2 pi/3) + i sin(2 pi/3) z + and so on... right?
No. If you have the geometric series
[tex]\sum_{n=0}^\infty r^n[/tex]
with |r|<1, what does it sum to?
  • · Replies 16 ·
