Summation equation for odd numbers?
  • Context: High School
  • Thread starter Thread starter aeonsky
    Numbers Summation
The discussion focuses on deriving the summation formula for odd integers between 1 and an odd integer n. The key formula identified is (N+1)(N+1)/4, where n is the odd integer. Participants confirm that the sum of the first k odd integers equals k², demonstrated through various examples, including the sums of the first six odd integers. The arithmetic properties of odd numbers and their relationship to squares are also highlighted, confirming that the sum of the first k odd integers results in k².
  • Understanding of arithmetic series and summation notation
  • Familiarity with basic algebraic manipulation
  • Knowledge of the properties of odd and even integers
  • Experience with mathematical induction for proofs
  • Research the derivation of the formula for the sum of the first k integers
  • Explore the concept of arithmetic sequences and their properties
  • Learn about mathematical induction and its applications in proofs
  • Investigate the relationship between odd integers and perfect squares
Mathematicians, educators, students studying number theory, and anyone interested in the properties of odd integers and summation techniques.
aeonsky
\sum_{i=1}^{n} i is the sum of all numbers between 1 and n.
I'm trying to find one for odd numbers where you need to find the sum of all odd numbers between 1 and n.
I tried 2n+1 which worked, only for first n numbers, not for numbers 1 to n.
Thanks for the help.
Mathematics news on Phys.org
Here is the sum of all the integers from 1 to an odd integer 2k + 1.
\sum_{i=1}^{2k + 1} i
To find the sum of the odd integers from 1 to 2k + 1, just subtract the sum of the even integers from the sum of all of the integers from 1 to 2k + 1.
For example, if you want the sum of the first 6 odd integers you can do this:
1 + 3 + 5 + 7 + 9 + 11 = 1 + 2 + ... + 11 - (2 + 4 + 6 + 8 + 10).
Presumably you know a formula for the sum of the first k integers. The expression in parentheses is 2(1 + 2 + 3 + 4 + 5).
I don't think I am quite looking for that.
I need to find the sum of all odd integers between 1 and odd integer n.
Thus, if you need to find (3), the sum will be 4. (5), the sum will be 9. (7), the sum will be 16.
I found the formula (N+1)(N+1)/4 where n is the odd integer, but not the summation formula.
By the way, is it appropriate to have an expression for the top limit for summations?
If n is odd then n = 2k + 1 for some integer k. So the sum becomes \sum_{i=0}^{k} (2i + 1). Now find k in terms of n, and hence a closed form.
Yes.
What Mark44 gave you will certainly help. The sum of all integers from 1 to n is, of course, n(n+1)/2. The sum of all even integers from 1 to n, assuming for the moment that n is even, n= 2k, is 2+ 4+ 6+ ...+ 2k-2+ 2k= 2(1+ 2+ 3+ ...+ (k-1)+ k) and its sum is 2[k(k+1)/2)= k(k+1). The sum of all odd numbers, from 1 to 2k+1, is the sum of all integers from 1 to 2k+1, (2k+1)(2k+2)/2= (2k+1)(k+1), minus the sum of even integers from 1 to 2k: the sum of all odd integers from 1 to 2k+1 is (2k+1)(k+1)- k(k+1)= (k+1)(2k+1-k)= (k+1)2.
Interesting result isn't it? Yes, 1+ 3= 4, 1+ 3+ 5= 9, 1+ 3+ 5+ 7= 16, etc. all squares.
Another reason why the sum of odd integers is a square:
The sum of odd numbers from 1 to 2k+1 is just an arithmetic series with "common difference" 2. An arithmetic sequence has the nice property that the average of all the numbers is just the average of the first and last numbers. Here the first and last numbers are 1 and 2k+ 1 so their average is (1+ 2k+ 1)/2= (2k+2)/2= k+ 1. There are, of course, k+1 odd numbers from 1 to 2k+1 so their sum is the average times the number of odd numbers, (k+1)(k+1)= (k+1)2.
Examples can easily handled this problem:
1 = 1^2
1+3 = 4=2^2
1+3+5 = 9 = 3^2.
However, to prove it you can use induction.
I don't know the equation, but, the sum of odd numbers 1 to n is equal to the square of however many odd numbers your adding together. The sum of the odd numbers from 1 to 19, the first 10 odd numbers, is 100. The sum of the first 30 is 900, the first 1000 odd numbers add up to 1,000,000.
Yet another way to get to the same place, is to imagine the sum of the first, say, 6 odd numbers, 1 + 3 + 5 + 7 + 9 + 11, as equal to the sum of the first 6 *even* numbers, 2 + 4 + 6 + 8 + 10 + 12 = 2(1 + 2 + 3 + 4 + 5 + 6)... but then subtracting one for each number you added (6, in this case).
In the general case, the sum of the first 'k' odd numbers is the sum of the first 'k' even numbers, minus 'k': that is, k(k+1) - k = k^2.
P.S. Oh gosh, the thread was 2 years old... Nevermind.
  • · Replies 0 ·
