Does Summation Over n from -∞ to +∞ in Quantum Mechanics Equal Ψ(x)?
The discussion centers on the summation notation in quantum mechanics, specifically whether the expression ∑cnexp(iknx) = Ψ(x) implies that n ranges from -∞ to +∞. It is argued that this range is necessary for consistency with Fourier series involving complex exponentials. The alternative, using n = 1 to +∞, is noted for cases where the expression relates to sine or cosine functions. Clarity on the range of n is emphasized as essential for proper interpretation. The importance of context in defining the summation index is highlighted.
knowwhatyoudontknow
Clarification of Summation index
see below
I have a (trivial) question regarding summation notation in Quantum mechanics. Does
∑cnexp(iknx) = Ψ(x) imply that n ranges from -∞ to +∞ (i.e. all possible combinations of n)? i.e.
n
∑exp(iknx)
I believe it does to be consistent with the Fourier series in terms of complex exponentials.
n = 1 to +∞ would then be used when exp(ikNx) -> sinx/cosx.
Just want to be absolutely sure. Thanks.
knowwhatyoudontknow said:
Homework Statement:: Clarification of Summation index
Relevant Equations:: see below
n
∑exp(iknx)
The range of ##n## should be stated or clear from the context.
  • · Replies 37 ·
  • · Replies 27 ·
  • · Replies 69 ·
  • · Replies 37 ·
