Summation Problem: Evaluate k2-k+1/k(k-1)
  • Thread starter Thread starter darkvalentine
    Summation
7 replies · 3K views
darkvalentine
Evaluate: Sum[k2-k+1/k(k-1),{k,2,infinity}]
k2-k+1/k(k-1) can be written as k/(k-1) - 1/k, but then I get stuck because when n->infinity, the sum is divergent.
Your notation is slightly ambiguous.
If this is your problem:
http://www.wolframalpha.com/input/?i=Sum+k^2-k%2B1/k(k-1)+from+2+to+infinity
then yes it diverges.
If the general term is
[tex] \frac{k^2 - k + 1}{k(k-1)}[/tex]
the key is that numerator and denominator are polynomials of the same degree: what is the limit of this term (not the sum, just this term) as [itex]k \to \infty[/itex]?
Thanks for input sir,
The limit of the term above when k->infinity is 1, but can I conclude that the lim(the sum above, k->infinity) = 1 also?
Now that I know what problem you need answer to I can give an answer. Instead of writing k2-k+1/k(k-1) write (k^2-k+1)/(k(k-1)) because the first one is not the same as the second one.
If you have
[tex]\sum_{n=0}^\infty a_n[/tex]
there is a specific property that [tex]a_n[/tex] needs to have when [tex]n \to \infty[/tex] for the sum to converge. Does your [tex]a_n[/tex] have this?
Tip: you just showed that it didn't.
Are you familiar with the limit comparison test? If so compare it to Bn = 1. This should also make it apparent that for ΣAn to converge it must be the case that: An → 0 as n → ∞
As others have noted, you know that the general term does not go to zero. What does that alone say about the series' convergence?
Thanks guy, I think I figure it out ))
