Summation Problem: Evaluate k2-k+1/k(k-1)
  • Thread starter Thread starter darkvalentine
    Summation
The discussion revolves around evaluating the infinite series Sum[k^2 - k + 1 / k(k - 1), {k, 2, infinity}]. Participants explore the nature of the series and its convergence properties.
  • Participants discuss rewriting the series and analyze the behavior of the general term as k approaches infinity. Questions are raised about the implications of the limit of the general term on the convergence of the series.
The discussion is active, with participants providing insights into the divergence of the series and the conditions necessary for convergence. There is an exploration of the limit comparison test and its relevance to the problem.
Some participants note ambiguity in the notation used for the series, which may affect interpretation. The discussion also touches on the requirement that the general term must approach zero for the series to converge.
darkvalentine
Evaluate: Sum[k2-k+1/k(k-1),{k,2,infinity}]
k2-k+1/k(k-1) can be written as k/(k-1) - 1/k, but then I get stuck because when n->infinity, the sum is divergent.
Your notation is slightly ambiguous.
If this is your problem:
http://www.wolframalpha.com/input/?i=Sum+k^2-k%2B1/k(k-1)+from+2+to+infinity
then yes it diverges.
If the general term is
[tex] \frac{k^2 - k + 1}{k(k-1)}[/tex]
the key is that numerator and denominator are polynomials of the same degree: what is the limit of this term (not the sum, just this term) as [itex]k \to \infty[/itex]?
Thanks for input sir,
The limit of the term above when k->infinity is 1, but can I conclude that the lim(the sum above, k->infinity) = 1 also?
Now that I know what problem you need answer to I can give an answer. Instead of writing k2-k+1/k(k-1) write (k^2-k+1)/(k(k-1)) because the first one is not the same as the second one.
If you have
[tex]\sum_{n=0}^\infty a_n[/tex]
there is a specific property that [tex]a_n[/tex] needs to have when [tex]n \to \infty[/tex] for the sum to converge. Does your [tex]a_n[/tex] have this?
Tip: you just showed that it didn't.
Are you familiar with the limit comparison test? If so compare it to Bn = 1. This should also make it apparent that for ΣAn to converge it must be the case that: An → 0 as n → ∞
As others have noted, you know that the general term does not go to zero. What does that alone say about the series' convergence?
Thanks guy, I think I figure it out ))
  • · Replies 17 ·
