Summation - Riemann Intergral -
  • Thread starter Thread starter Mattofix
    Riemann Summation
The discussion focuses on calculating the upper and lower Riemann sums for the function f(x) = exp(-x) over the interval [0,1]. The upper sum is expressed as the sum from i=1 to n of exp(-i/n)/n, and the user is unsure if this is correct and how to proceed. They mention needing to take the limit as n approaches infinity to find the final upper sum. The lower sum is proposed as the sum from i=1 to n of exp((1-i)/n)/n. The conversation emphasizes the importance of correctly applying the limit to determine the Riemann integral.
Mattofix
[SOLVED] Summation - Riemann Intergral - URGENT
Im working on the upper and lower riemann sums of f(x) = exp(-x)
where Pn donates the partition of [0,1] into n subintervals of equal length (so that Pn = {0,1/n,2/n,...,1})
So far i have the upper sum to be the sum from i=1 to n of exp(-i/n)/n - is this right? - if so where do i go from here? I think I am meant to take the limit when n-> infin which should give the final upper sum. I hope this right...
...and the lower sum to be the sum from i=1 to n of exp((1-i)/n)/n ?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 26 ·
