Super-Earths around binary dwarf stars
  • Thread starter Thread starter RyderP
    Binary Stars
22 replies · 3K views
RyderP
I may be writing a story, set on a rocky planet, 15 times the size of Earth, around a binary dwarf star (one red, one orange). What kind of flora and fauna can I expect?
Well, the flora and fauna will vary depending on the type of vegetation you choose i.e. if you want the time-honoured traditional slimy one-eyed species or want to create something fresh, new and unconventional.
Actually, I want something a little more true to life.
On the other hand, how about combining Star Wars, Space: 1889, and D&D?
I also know thar the sky will, most likely, be orange.
And, how about these races:
Human
Elf
Half Elf
Halfling
Ogre
Gnome
Dwarf
Goblin
How about this for a currency:
15 florins = 1 ducat
30 ducats = 1 kreutzer
Electrum = 1
Copper = 3
Silver = 5
Gold = 10
Sorry I got carried away.
Human
Elf
Half Elf
Halfling
Ogre
Gnome
Dwarf
Goblin
Add the Todi (insectoids) and the Morrix (delphinoids).
How much gravity can I expect from a planet orbiting a red and an orange dwarf star?
Gravity of a planet does not depend on the type of the parent star(s).
All that matters is its size and density. So...
If you mean 15 times the radius, and assume the same or very similar composition, then it'd by 15 times Earth's gravity. At that size, the planet would also be unlikely to be a terrestial planet any more. It would likely be a dwarf star itself, actually.
However, if you mean 15 times the surface area, then the planet would be approx 4 times larger than Earth in terms of radius, and with 4 times the gravity. You could fudge the density a bit to bring the gravity to about 3g, but anything lower than that would be improbable.
As a rule of thumb, you get as many times higher/lower gravity as many times the planet (its radius) is larger/smaller than Earth's.
How much could you reduce gravity at the equator by having the planet rotate very fast? Perhaps due to a collision 10 million years ago. You'd then have an obviously non round planet, and lots of heavier elements in the crust.
And, what about the magnetosphere?
You can use the surface gravity equation
g = 4π/3 × G ×ρ × r
Four thirds pi times gravitational constant times density times radius. So a planet with Earth's density, 5514 kg/m3, and 15x radius you get:
g = 4.19 × 6.674 10-11× 5514 × (15 ×6371000) = 147.
Which is also 15x Earth's gravity.
However, that rule of thumb does not work. Saturn has around 1g and radius 10x Earth's radius because Saturn is has a lot of hydrogen and Earth has a lot of iron. Jupiter has a lot of hydrogen too but 15x radius and 2.5x gravity. Mars has 0.38g and 0.5 radius and is similar to Earth in composition. Mercury comes close to your thumb with .38g and .38 radius but only because Mercury has more iron and Earth has a lot of oxygen and silicon.
A 15x radius iron planet will compress the electrons in the core. A planet made out of the same materials as Earth does has a much higher density.
RyderP said:
So, 3G's okay?
3g is acceptable. Magnetosphere should not be a problem.
It works for terrestial planets - i.e. under the somewhat stretched assumption of Earth's density. If you want to add density to the mix, then it's another simple linear relationship.
I was thinking of making the magnetosphere of the planet more like what Earth's would have been, if Tesla had his way.
So that only longwave, shortwave, and hyperspace radio work. And local comm systems are provided by direct use of the magnetosphere.
And make glass glow, while we're at it. Why not?
doesn;t all glass glow when you shine lights on it?
edit, I forgot your original plan. Your dwarfs should have supercondutive armor plates. than they can float.
I'm afraid I don't understand your edit.
