Superball bouncing on a moving train and Galilean invariance
34 replies · 5K views · last reply
Magatron
TL;DR
A thought experiment puzzle involving the Gallilean Invariance theory
Gallilean Invariance states that the laws of motion are the same in all inertial frames. One experiment involved being on a ship below deck with no frame of motion reference. Supposedly, there is no experiment which could show whether the ship is moving or in what direction or speed. I was thinking about this theory and I imagined a superball being bounced off a wall on a moving train. The results of this thought experiment, since I can't carry out the experiment in the real world currently, seemed contradictory to me. See if you can figure out this puzzle.
A person on a train moving at 100 mph throws a superball in the direction of the train's motion at a speed which is to him 100 mph. When it hits the wall and bounces, assuming 100% bounce efficiency and straight paths, how fast will it appear to return to the thrower? For it to appear to him to return at 100 mph it would have to stop dead in relation to the train tracks at the moment it hit the wall, because he's moving at 100 mph toward it so his motion alone would provide the full 100 mph.
However, from the viewpoint of the train tracks, or an observer on a bench by the tracks, it would appear that the ball when thrown was moving at 200 mph, the train speed plus the throw speed. Since the wall is only moving at 100 mph, the ball should bounce back at 100 mph relative to the observer and the thrower should see it returning to him at 200 mph, rather than 100. The stationary observer would not see the ball stop dead, they would see it bounce back at 100 mph, would they not? So how can this be? Does the ball stop dead and wait for the thrower to catch up to it at 100 mph or does it bounce back at 100 mph relative to the track and close in on the thrower at 200 mph? I don't know the answer myself, it just seems contradictory.
It only seems contradictory because you simply assumed contradictory results without actually working it out quantitatively. If you use the conservation of energy and momentum and actually work it out then there is no contradiction.
Magatron said:
However, from the viewpoint of the train tracks, or an observer on a bench by the tracks, it would appear that the ball when thrown was moving at 200 mph, the train speed plus the throw speed. The stationary observer would not see the ball stop dead, they would see it bounce back at 100 mph, would they not?
If you do the calculations for this collision using conservation of energy and momentum, then the trackside observer will see the ball stop dead.
Elastic collisions are characterised by the same separation speed before and after collision. In the frame of the tracks, that separation speed is ##100 mph## - before and after. The horizontal speed of the ball after the collison is, therefore, ##0 mph##.
Your main error: If the wall is moving, a 100% elastic collision doesn't preserve the speed of the ball.
A general problem of your post. You fail to stick to one reference frame in either paragraph, and keep mentioning velocities relative to the other frame. This approach is bound to confuse you.
So which is it, stop dead or bounce back at 100 mph from the a stationary observer's viewpoint?
Stop dead.
PeroK said:
Stop dead.
So it will go from 200 mph to zero just because it hit a 100 mph wall? Wouldn't a 200 mph ball hitting a 100 mph wall be the same as a 100 mph ball hitting a stationary wall? What would happen in that case, the ball would just stop and stay stuck to the wall?
Yes. The ball rebounds so that the separation velocity is 100 mph, all of which is accounted for by the motion of the wall.
Yes. The ball rebounds so that the separation velocity is 100 mph, all of which is accounted for by the motion of the ball.
If you have conservation of energy and momentum, then yes. Do the math, as they say.
But, of course, the easiest way to solve that problem is to transform to the frame where the train is at rest. Then it's what you calculated for the train frame. Then transform back. And, when you transform back then ##- 100mph## in the train frame becomes ##0 mph## in the ground frame.
It's the same in the sense that it's the same physical event viewed from two different frames. That's why you can do the calculations in the rest frame of the train/wall, then transform back.
But, if you do the calculations in all the ground frame, then it comes out the same. The ball stops in the ground frame. Which is equivalent to rebounding in the wall frame.
You raised this as a paradox. But, I get the feeling you are disappointed that there is no paradox. When you do the maths, the paradox disappears. I'm sorry!
Yes
Yes
In both cases the wall and ball move apart at 100mph. You've just got two frames, one where the wall moves away from a stationary ball at 100mph and one where the ball moves away from the stationary wall at 100mph.
Same frame invariants. Different frame dependents, like the final velocity of the ball
No, that is a different frame invariant outcome.
Ibix said:
Yes
Yes
It doesn't make sense that something moving at 200 mph could be stopped cold by hitting something moving half that speed. Common sense says that it will bounce back at 100 mph.
That just shows that if we were dependent on your common sense there wouldn't be much science to talk about!
Anyway, the proof is to do the experiment. Not that easy to set up, though. But, experiments don't care about your common sense either.
This is the nearest I could find:
Last time I checked, the surface of the Earth where I live was moving eastward at about 600 or 700 miles per hour. Yet I've never had problems bouncing a super-ball off either east-facing or west-facing walls.
Nor have I ever had to account for time of day and the Earth's motion around the sun.
Sounds more like nonsense. Why would tennis players swing the racket towards the incoming ball, if that wouldn't increase the final speed of the ball? Conversely if the racket is moving away, the ball's final speed will decrease.
Stop dead in the embankment frame.
It's what happens, at least assuming that the wall is hugely more massive than the ball. So I would suggest you need to adjust your notion of "common sense".
It's worth noting that it took us until the 1600s to figure this out, and we'd been walking the Earth for the better part of 10,000 years at that point. But it's trivial to work out. In the frame where the wall is stationary the ball approaches at +100mph and rebounds at -100mph. If you switch to a frame where the wall is doing +100mph, you need to add 100mph to all velocities. The zero of the wall becomes +100mph. The incoming ball velocity becomes +200mph and the rebound velocity becomes (-100+100)=0mph.
I guess you're right, it just seems odd. It really is something where you would have to see it to believe it. What about this though? If the wall was stationary and the ball hit it at 200 mph it would bounce from that point in space at 200 mph. So if the wall is moving at 100 mph then the ball should bounce back from that point in space at 100 mph. How could it not? The only thing that changed was that 100 mph was added in one direction, thus 100 mph should be subtracted from the other direction, leaving the ball moving at 100 mph from that point in space. Why would adding 100 mph in one direction result in subtracting 200 mph in the other?
I'm having trouble parsing this. It doesn't seem to correspond to anything in the maths, which you look to have done correctly. Perhaps you could rephrawe your question?
The next time you're cruising in an airplane bounce a ball off the back wall. Also do it off the front wall.
Your common sense is correct. The ball will bounce back at
100 mph relative to the wall, since that is the speed at which
it hit the wall. Its speed relative to you will be zero. That is a
change in the ball's speed relative to you of 200 mph. It was
going toward the wall at 100 mph, now it is going away from
the wall at 100 mph, and that is 0 mph relative to you.
That is just common sense, plus not conflating reference frames.
-- Jeff, in Minneapolis
The airlines do not care for this. Or <cough> so I've been told.
We assume person A is on board the train throwing the ball towards the front of the train, or in the direction the train is traveling, if it is traveling. Person A is throwing the ball towards a wall which could be either inside the train, at the front of the car person A is on, or outside the train, next to track, perpendicular to the track, in which such case, person A throws it outside the window. We assume the angle between the path of the ball and the track is negligible. Tje ball impacts the wall, and rebounds in an elastic collision. Person B is an observer standing near the track. v is the velocity of the ball from the point of view of the person A, shortly after person A threw it. Velocity in the direction the train is moving is positive. Velocity opposite from that the train is moving is negative. When the train is moving, it goes 100 mph. We discuss three scenarios, the wall inside the train while the train is motionless, the wall is inside the train while the train is moving, and the wall is outside the train while the train is moving. For each, I give the velocities for the following reference frames, person A, person B, the ball while traveling from person A to the wall, and the ball while traveling from the wall to person A.
I. Wall inside train which is not moving
A. person A
person A = 0
wall = 0
ball traveling from person A to wall = v
ball traveling from wall to person A = -v
B. person B
person A = 0
wall = 0
C. ball traveling from person A to wall
person A = -v
wall = -v
ball traveling from person A to wall = 0
D. ball traveling from wall to person A
person A = v
wall = v
II. Wall inside train which is moving
A. person A
person A = 0
wall = 0
B. person B, add 100 to above values for person A
person A = 0 + 100 = 100
wall = 0 + 100 = 100
ball traveling from person A to wall = v + 100
ball traveling from wall to person A = -v + 100, which may be either positive or negative, depending on the value of v
person A = -v
wall = -v
person A = v
wall = v
II. Wall outside train which is moving
A. person A
person A = 0
wall = -100
wall = -100 + 100 = 0
person A = -v
wall = -v + (-100) = -(v + 100)
person A = v
wall = v + (-100) = v - 100, which may be either positive or negative, depending on the value of v
Someone mentioned tennis rackets. If you swing a tennis racket, from the reference frame of the racket, the racket is motionless, so if the ball hits at v, it rebounds at -v.
The original poster wrote "So it will go from 200 mph to zero just because it hit a 100 mph wall? Wouldn't a 200 mph ball hitting a 100 mph wall be the same as a 100 mph ball hitting a stationary wall? What would happen in that case, the ball would just stop and stay stuck to the wall?" When they say "zero", they are not implying that the ball "would just stop and stay stuck to the wall". The velocity is only 0 mph for an instant. Before that, it is v, and after that it is -v.
Somebody said, "we'd been walking the Earth for the better part of 10,000 years at that point". The human species evolved 200,000 years old.
I guess you really are right, even though it seems weird, because if the thrower moved out of the way so the ball bounced off the rear wall after bouncing off the front wall, the wall would hit the stationary ball at 100 mph and make it move at 200 mph toward the front wall in relation to the track. So an observer by the track would see the ball repeatedly go forward at 200 mph, stop dead, and go 200 mph again. One side of the bouncing being 200 mph and the other being zero mph, they average out to the same as 100 mph each side, so the math is consistent even though the results look weird when observed.
Magatron said:
... even though the results look weird when observed.
It doesn't look that weird, because even if you watch it from the ground, the brain often picks up the relative motions of the interacting objects (ball & train), rather than the motions relative to you. It also depends on what you are tracking with your eyes.
A.T. said:
It doesn't look that weird, because even if you watch it from the ground, the brain often picks up the relative motions of interacting object (ball & train), rather than the motions relative to you. It also depends on what you are tracking with your eyes.
Agreed. I think this is actually why the results of frame changes are so unintuitive. Your brain is so good at mixing frames that the results of formal analysis in a single frame seems weird. Just look at the Mythbusters video in #13. They don't just shoot a cannon out of a truck - they are extremely careful to do it in front of a strongly patterned background, right in front of a vertical line in the pattern. Physically, that yellow/black chessboard is irrelevant, but it seriously cuts down on the tricks your brain can play on you.
Note that this is similar to what an outer point on the wheel of a driving car does, in the frame of the ground. Its horizontal velocity oscillates between zero and twice the car speed. But intuitively people just interpret the wheel as "spinning", for the reasons I gave in post #25.
A. person A
person A = 0
wall = -100
This is not correct. A ball rebounding elastically from an approaching wall will increase in speed.
A natural way to work the correct results out is to shift to the ground frame. The ball is now traveling at v + 100 and rebounds elastically from the stationary wall at -v - 100.
Shifting into the train frame, the new velocity becomes -v - 100 - 100 = -v - 200.
One might feel uncomfortable with this. In the train frame we are told that this is an elastic collision but it is clear that energy has increased. The ball is going faster than it started. However, a careful accounting for energy reveals that all is well. The collision with a moving wall does work on the wall. The moving wall slows down. No matter how massive the wall is, the work done is roughly the same.
In the train frame, the ball gains energy and the wall loses energy.
In the track frame, no energy changes hands.
This is acceptable because energy is not an invariant quantity -- it changes depending on your frame of reference.
Right, otherwise tennis wouldn't work. The elastic collision in different frames is visualized at the beginning of this video:
Magatron said:
it just seems odd.
This applies to many situations and it's why confidence tricksters still regularly relieve people of their money. You just can't trust intuition; you have to do the (right) sums.
