Supercooled Steam Homework: Solving for Tf, Condensation Fraction & ΔS
The discussion centers on a thermodynamics homework problem involving 0.50 mol of supercooled steam at 95˚C and 1 atm pressure. The key findings indicate that the final equilibrium temperature after condensation is 100˚C, as the steam must reach the boiling point to avoid being supercooled. The condensation fraction can be determined by equating the heat gained by the condensing water to the heat lost by the steam. The change in entropy (ΔS) for the process can be calculated using the formula ΔS=n*Cp*ln(Tf/Ti).
  • Understanding of the ideal gas equation (PV=nRT)
  • Familiarity with thermodynamic principles, particularly heat transfer at constant pressure
  • Knowledge of the specific heat capacity (Cp) of water and steam
  • Ability to calculate change in entropy (ΔS) using thermodynamic equations
  • Calculate the heat of vaporization of water at 100˚C
  • Learn about the concept of condensation fraction in thermodynamic systems
  • Explore the implications of supercooling in phase transitions
  • Study the application of the first law of thermodynamics in closed systems
This discussion is beneficial for students studying thermodynamics, particularly those tackling phase transitions and heat transfer in gases and liquids. It is also relevant for educators and professionals in physics and engineering fields.
Ariel Jo
You have 0.50 mol of steam which has been supercooled to 95˚C at 1 atm. Since the steam is below the boiling/condensation point, it proceeds to partially condense into liquid water. This happens in a thermally-insulated vessel at constant pressure.
(a) When the system re-attains equilibrium, what will the final temperature be?
(b) What fraction of the water will condense?
(c) Calculate ΔS for this process.
ideal gas equation (the gas is assumed to behave ideally)
deltaS=n*Cp*ln(Tf/Ti)
From PV=nRT, obtained an initial volume of steam of 15.1L but unsure how to proceed... Vf and Tf are both unknowns but should not be equal to Vi and Ti (from common sense - steam at 95degC will both condense and cool spontaneously.) Can easily find change in entropy from knowing final temperature... Would U=3/2RT be useful in this situation?
Some hints:
Lacking other data, assume the water condenses until it reaches equilibrium.
Since the pressure is held constant, assume the volume is variable.
This seems to give a final temperature of 100º C. (The boiling point of water.)
So the basic question seems to be, how much water has to condense to heat the vapor back to 100º C.?
q(gained by water)=q(lost by steam), and at constant pressure this would be q=n*Cp*deltaT for both substances. Setting them equal to each other would give moles of each, but there are no calculations to get 100degC as the equilibrium temp, just the (seemingly sound, but I'm not a physics specialist) logic that for steam to not be supercooled it must be at 100degC or higher (when the pressure is a constant 1atm), if I understand you correctly.
Thanks for the help!
How much heat is given off (per mole) when steam condenses to liquid water at a constant temperature of 100 C? What is the heat of vaporization of water at 100 C?
Chet
