Can Superheated Steam Reach 1000°C?
  • Thread starter Thread starter Yashbhatt
    Steam
Superheated steam can indeed reach temperatures of 1000°C at sufficiently high pressures, provided the right materials and conditions are utilized. The specific enthalpy (h = H / m) plays a crucial role in determining the amount of thermal energy required. A robust pressure vessel is necessary to contain the steam at this temperature, and materials must retain strength at high temperatures. Most commercial power plants operate around 500°C for optimal thermodynamic efficiency without incurring excessive material costs.
  • Understanding of thermodynamics and specific enthalpy
  • Knowledge of pressure vessel design and materials science
  • Familiarity with steam generation and heating processes
  • Basic principles of biomass combustion and energy conversion
  • Research materials that maintain structural integrity at 1000°C for pressure vessels
  • Explore advanced steam generation techniques and their applications
  • Investigate the economic implications of operating at high steam temperatures
  • Learn about biomass combustion efficiency and alternative heating methods
Engineers, thermodynamicists, and energy professionals involved in steam generation, biomass energy production, and high-temperature material applications will benefit from this discussion.
Yashbhatt
Is it possible to heat steam to a 1000°C at sufficiently high pressures?
If yes, what is the best way to do it?
Science news on Phys.org
Well, of course it is.
One simply needs a mass of water, inject the appropriate amount of thermal energy. The amount of superheat depends specific enthalpy, h.
h = H / m, where H is the enthalpy or thermal energy, and m is the mass.
Superheated steam behaves much like an ideal gas.
One simply needs a pressure vessel strong enough to contain the steam at 1000°C. The pressure will depend on the mass enclosed and the volume - roughly PV = nRT.
The trick is finding a material which retains a modest amount of strength at 1000 C.
"Sufficiently high pressure" for what?
Depends on what you want to do with it.
I believe that most commercial power plants try to work with steam around 500 C or thereabouts. That hits the economic sweet spot of temperatures high enough for reasonable thermodynamic efficiency, but not so high that wildly expensive and exotic materials are required.
I need it to heat biomass.
1000°C seems excessive for process heat.
Economically, one would desire the minimum amount of heat input to achieve the desired goal of producing what you want from biomass.
I did find a link about boilers where it says that it can be heated to a thousand degrees. It has some sort of blueprint, so I think it should be commercial.
See this : http://feed-the-beast.wikia.com/wiki/Steam_Boiler
I don't think you are heating biomass in this boiler, you are burning it to provide the heat to turn water into steam. If you were just heating the biomass, the high temperature would drive off any water left in the biomass and you would be left with a hot pile of carbon, if that hasn't already burst into flame.
The website referred to in Post #8 is discussing some sort of computer game or simulation about building a railroad, and the boiler and other equipment discussed is not actually real.
Oh. But it seemed as if it were real.
And yes the purpose is actally ro burn biomass.
I found a technique which uses two honeycomb like ceramic things as heat exchanger.
Why would you try to burn biomass with steam? Why not just light it on fire? And why are you trying to burn the biomass?
This really doesn't make any sense.
That's what makes simulations useful. They seem real.
In any event, the info you linked to was from a simulation game called Railcraft, which itself was an offshoot or development of another game called Minecraft:
http://railcraft.info/wiki/
http://en.wikipedia.org/wiki/Minecraft
  • · Replies 26 ·
  • · Replies 60 ·
15K
