Solve Surface Area Problem: Sphere & Cylinder
To find the surface area of the sphere x^2 + y^2 + z^2 within the cylinder x^2 + y^2 = ax, a parametric equation for the sphere is proposed using spherical coordinates. The surface area integral is expressed as ∫∫ a^2*sinφ dφ dθ, but the boundaries for φ remain unclear. The discussion also explores an alternative approach using cylindrical coordinates, leading to the expression ∫∫√(4r^4 + r^2) dr dθ with specified limits for r and θ. Concerns are raised about the assumptions regarding the cylinder's orientation and the validity of the r boundaries. The conversation emphasizes the need for clarity in the integration limits and the geometric interpretation of the problem.
bodensee9
I am wondering if someone could help me with the following? I am supposed to find the surface area of the part of the sphere x^2 +y^2+z^2 that lies inside the cylinder x^2+y^2 = ax.
If I wanted to write a parametric equation for the sphere, I would use x = ρsinφcosθ and y = ρsinφcosθ and z = ρcosθ. Let r be the vector function given by xi +yj +zk. So, since the surface area = ∫∫|(dr/dφ) x (dr/dθ)|dφdθ. So if I do that with the following, I have |(dr/dφ) x (dr/dθ)| as a^2*sinφ. So, the surface area should be ∫∫a^2*sinφdφdθ.
I am trying to figure out the boundaries of integration. I see that the cylinder has the expression r = acosθ. So θ would be between –π/2 and π/2. But I am not sure what φ should be?
Alternately, I tried with cylindrical coordinates. So, I have that for the sphere I would use x = rcosθ, y = rsinθ, and z = a^2 - r^2. And if I let f be the vector function represented by x,y, and z, then df/dr = <cosθ, sinθ, -2r> and df/dθ = <-rsinθ, rcosθ, 0> And so if I take the cross product of the two vectors I would get 2r^2cosθ -2r^2sinθ +r. So |(df/dr)x(df/dθ)| is 4r^4 + r^2. So would the expression be ∫∫√(4r^4+r^2)drdθ where 0≤r≤rcosθ and –π/2≤θ≤π/2? Thanks!
The problem with your assumption about the cylinder formula is that the one in your problem can have its axis somewhere other than a coordinate axis. What if you kept it in rectangular (x,y,z) coordinates?
The condition 0≤r≤rcosθ seems dubious...
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
