Why are the Two SSA Equations the Same in a Catalytic Cycle?
  • Thread starter Thread starter i_love_science
    Reaction
The discussion centers on the derivation of the rate law for a surface-catalyzed isomerization reaction represented by the mechanism A + S -> A-S and A-S -> P + S. The rate of formation of product P is expressed as d[P]/dt = k'[thetaA], where thetaA is defined as thetaA = [A-S] / ([S] + [A-S]). The steady-state approximation (SSA) is applied to both intermediates, leading to the conclusion that the two SSA equations are equivalent due to the nature of the catalytic cycle. This equivalence results in the elimination of the concentration of S from the rate equations while still influencing the overall reaction kinetics.
  • Understanding of Michaelis-Menten kinetics
  • Familiarity with steady-state approximation (SSA)
  • Knowledge of reaction mechanisms in catalysis
  • Basic principles of stoichiometry in chemical reactions
  • Study the derivation of Michaelis-Menten kinetics in detail
  • Explore advanced applications of the steady-state approximation in catalysis
  • Research the implications of reaction mechanisms on rate laws
  • Investigate the role of intermediates in catalytic cycles
Chemists, chemical engineers, and students studying reaction kinetics and catalysis will benefit from this discussion, particularly those focusing on surface-catalyzed reactions and the application of steady-state approximations.
i_love_science
The following is a basic surface-catalyzed isomerization reaction:
A -> P
This can be modeled by the following mechanism:
A + S -> A-S
A-S -> P + S
The text is trying to derive the rate law for the formation of P.
d[P]/dt = k[A-S]
It can also be written as
d[P]/dt = k'[thetaA], where thetaA is the fraction of sites to which a reactant is bound.
We are trying to find an expression for thetaA, which the text gives as
thetaA = [ A-S ] / [S]+[ A-S ]
Since thetaA contains intermediates, we need to get rid of both [S] and [A-S], by applying the steady-state approximation to both.
d[A-S]/dt = k1[A] - (k2 + k-1)[A-S]
d[S]/dt = -k1[A] + (k2 + k-1)[A-S]
This is the part I don't understand:
Because we have a catalytic cycle, the two halves of the cycle fit together perfectly, and the two SSA equations are the same.
Can anyone explain to me why that is the case? Thank you!
Chemistry news on Phys.org
Hi,
thetaA = [ A-S ] / +[ A-S ]
Are you certain this is what the text says ? [ A-S ] / [ S ] seems so much more sensible 🤔 !?
what are k1, k2 and k-1 (or did you mean k-1 ? Makes a difference ! )
the second d/dt : of what ?
The forum interprets [S] as command to strike-through the following text. To avoid that you can write [plain][S][/plain], it will be shown as [S]. Or simply add a space: [ S] is ignored by the forum. I fixed the initial post, it should look as intended now.
BvU said:
Hi,
Yes, I meant k-1, k1, and k2. It is d[S]/dt.
I made the edits, could anyone help me out with my question? Thanks!
A -> P
A + S -> A-S
A-S -> P + S
This is a Michaelis-Menten kinetics. It is typical for enzyme reactions but it also applies to many other catalytic reactions with a preceding equilibrium.
I assume you actually mean thetaA = [ A-S ] / ([S]+[ A-S ])
You are right. The two equations are redundant and give you [A-S] only. [S] (and therefore also thetaA) remains unknown.
S is obviously assumed to be present in large access. That justifies the steady state for [S] and turns the first elementary reaction A + S -> A-S into a pseudo-first-order reaction with [S] included into the rate constant k1. But that would mean that [S] is eliminated from the rate equations while it is still present in thetaA. I have no idea how to solve this problem.
I would use the original second-order kinetics instead:
d[A-S]/dt = k’1[A][S] - (k2 + k-1)[A-S] = 0
That results in
[A-S] = k’1[A][S]/ (k2 + k-1)
and
thetaA = [ A-S ] / ([S]+[ A-S ]) = k’1[A]/( k2 + k-1 + k’1[A])
[S] is still hidden in k' but that's not a problem because it is a constant factor as long as it remains stationary. It is rather confusing that k' also includes [A]:
k’ = k·([S] + [A-S]) = k2 [S](1+ k’1[A]/(k2 + k-1))
In the equation d[P]/dt = k'[thetaA] it looks like a constant but it actually isn't.
Maybe the intermediate [A-S] is assumed to be very instable. That would result in
k’1[A]/(k2 + k-1) << 1
and therefore in
k’ ##\approx## k2 [S]
That would also imply
thetaA ##\approx## k’1[A]/(k2 + k-1)
and therefore
d[P]/dt ##\approx## k1k2/(k2 + k-1)[A]
PS: I just realize that k’1[A]/(k2 + k-1) << 1 may also result from very low concentrations of A (and not only from an instable complex [A-S]). However, I'm still not sure how to finish the derivation using the pseudo-first-order kinetics for A + S -> A-S.
A -> P
A + S -> A-S
A-S -> P + S
Why do d[A-S]/dt and d[S]/dt turn out to be the same in terms of what is going on in the reaction?
Is the rate d[P]/dt considering both reaction steps? Is [A-S] considered the product and [S] considered the reactant, or vice versa?
Thanks!
The reaction rates must be equal and opposite because every S reacts to an A-S and every A-S reacts back to an S. You don’t even need the reactions to see that. It is just stoichiometry. The sum of the free and occupied surface areas remains constant:
[S]0 = [S] + [A-S] = const.
That results in the rates
d[S]0/dt = d[S]/dt + d[A-S]/dt = 0
Yes, it does. The rate equation for P is based on the last reaction step only. However, this equation contains the concentration [A-S] of the intermediate which is formed in the first step. Therefore it depends on the first step too. There is no A-S -> P + S without A + S -> A-S.
That depends on the reaction steps. A-S is the product of the reaction step A + S -> A-S and the reactant of the reaction steps A-S -> A + S and A-S -> P + S. For S it is the other way around.
Thank you! I understand now.
  • · Replies 19 ·
9K
  • · Replies 0 ·
