Surface of a sphere intersecting two cylinders
2 replies · 4K views · last reply
jarondl
Find the surface area of the surface [tex]x^2 + y^2 + z^2 = a^2[/tex], that is outside the two cylinders [tex]x^2+y^2=\pm ax[/tex].
[tex](a>0)[/tex]
[tex]ds= \sqrt{1+(Z_x')^2+(Z_y')^2}dxdy[/tex]
The intersections are clearly four ellipses. I will try to find a area of one of these ellipses in order to multiply it by four and subtract that from the known area of a whole sphere.
I have tried two different attitudes to solve it. First, I used the equation mentioned above, to convert this integral to a double integral.
[tex]S = \iint_D \sqrt{\frac{a^2}{a^2-x^2-y^2}}dxdy[/tex] when D is a circle given by [tex]\left(x-\frac{a}{2}\right)^2 + y^2 \le \left(\frac{a}{2}\right)^2[/tex]
Alas, I haven't succeeded in solving this one (not when staying cartesian, nor with polar co-ordinates).
The second idea was to use spheric coordinates in the first place, but then the limits for theta and phi turn out to be [tex]0<\phi < \frac{\pi}{2} , -a\cos\phi<\sin^2\theta < a\cos\phi[/tex] Which ain't nice either.
ANY help would be appreciated, especially before my exam on Sunday
Thanks,
Jaron
Welcome to PF!
Hi Jaron! Welcome to PF! :smile:
[tex](a>0)[/tex]
Nooo … it's not even a plane figure … an ellipse is a plane figure, and any plane intersects a sphere in a circle, but these cylinders in ellipses.
e it.
hmm … clever isn't always the easiest. :wink:
have you tried the dumb approach, just using horizontal slices of thickness dy?
(and didn't Archimedes have a theorem about areas on spheres and cylinders?)
Thanks tiny Tim!
Yep.. You were right.
About Archimedes, I only find his ideas over a cylinder of the same radius as the sphere.
Anyway, thanks for you help
