How does Bernoulli's equation relate to surface pressure on an isothermal plate?
  • Thread starter Thread starter BMWPower06
    Pressure Surface
Bernoulli's equation is central to understanding how surface pressure varies on an isothermal plate given a free stream velocity. The discussion emphasizes that as the velocity of the fluid increases, the pressure must decrease to maintain a constant value in the equation. Participants clarify that the goal is to plot surface pressure changes based on the relationship between velocity and distance, using a known initial pressure of 300 kPa. The conversation highlights the importance of understanding how changes in velocity affect pressure rather than focusing on the numerical value of the constant in Bernoulli's equation. Overall, the thread provides guidance on applying Bernoulli's principles to solve the problem effectively.
BMWPower06
Surface Pressure Equation??
Given pressure and the free stream velocity as well as the temperature of the isothermal plate.
This is where I'm lost?
It asks me to plot the surface pressure at the isothermal plate for a range of x=0 to x=1 given that I have a free stream velocity of 10*x
Can someone help me, I'm not sure what the equation is for surface pressure.
Thanks
any help?
Have you tried Bernoulli's equation?
are you referring to this equation?
Do I just solve for P in the above equation and that will give me surface pressure? What constant value do I use?
The problem gives you a free stream velocity relationship using distance as the independent variable. What the problem wants you to show is how P must vary as v changes so that Bernoulli's equation is satisfied.
So do I solve for P/V=
Also, I'm still confused as to what the constant in the equation above represents?
Thanks
Thanks
any help?
The point of Bernoulli's equation is not to determine the numerical value of the constant. One uses the fact that a change in anyone of the quantities on the LHS of the equation (like the velocity of the fluid) will cause a change in the other quantities. For example, if the velocity of the stream increases and there is no change in elevation, then pressure must decrease, so that the constant, whatever it is, doesn't change.
Ahh okay, so basically at x=0 the pressure is 300kPa. So to plot the change in surface pressure I would do the following:
300 - [(1/2)*rho*(Uinfinity^2) - (rho*g*x)]
Where Uinfinity is the free stream velocity.
Is that correct? Since I am given that the pressure a tthe surface plate is 300kPa?
Thanks for the help SteamKing!
I would rewrite Bernoulli's equation so that you had [v, z, p] @ loc. 1 = [v, z, p] @ loc. 2
Then it would be clear how P changes as v changes with location.
