Surface representative of homology class.
  • Context: Graduate
  • Thread starter Thread starter WWGD
    Class Surface
15 replies · 6K views
Hi, everyone:
I wonder if anyone knows the actual definition of
having a surface represent a homology class. Sorry to bother with
just a definition, but I have not been able to find one , neither in books
nor online. I am reading
that a certain surface represents H_2(M,Z) , the second homology
class of an orientable manifold. All I can see is mention of
the inclusion map (and its pushforward), and the fundamental
class ( a generator of top homology).
Anyone know the def., or can give me a link/reference?
Thanks.
Elements in homology groups are equivalence classes of subobjects of the manifold (in this case). I apologise if I get this the wrong way round: they are the cycles. Two such subobjects represent the same element in the homology group if they are homologous, i.e differ by a boundary. Again I apologise if I have things wrong way round and have just described cohomology.
In the case in question it might help if you say what M is.
I meant did you have a particular manifold in mind so that someone could explain what the elements in H_2 are.
The picture I have for the torus, T, is that the generators of H_1 are loops, the same two loops as the fundamental group, and these are 1-submanifolds of T.
Let [tex]N[/tex] be a manifold, [tex]M\subseteq N[/tex] a compact oriented submanifold without boundary, [tex]\dim(M)=n[/tex].
[tex]M[/tex] has a fundamental class [tex][M]\in H_n(M)[/tex].
Then the homlogy class representing [tex]M[/tex] in [tex]N[/tex] is the image ("pushforward") of [tex][M][/tex] under the map (induced by inclusion) [tex]H_n(M)\to H_n(N)[/tex].It is possible to extend this to the case where M is allowed to have a boundary that is contained in the boundary of N. The only difference is that the homology relative to the boundary is used instead of absolute homology.
WWGD said:
Hi, everyone:
Thanks.
Every closed orientable manifold has a top dimensional Z homology cycle called the fundamental cycle. This cycle generates its top dimensional homology group. When the manifold is a subset of another manifold then this fundamental cycle is also a homology cycle in the larger manifold.
The fundamental cycle of a sub-manifold is said to be the homology cycle that it represents. So your surface represents its fundamental cycle inside the larger manifold.
One thing though. The important thing is not that the larger manifold is orientable but that the sub-manifold is orientable. If the sub-manifold is not orientable it will not represent a cycle. It has no fundamental class over Z. If it is orientable then its fundamental class will be a cycle whether or not the larger manifold is orientable.
For example the Klein bottle is not orientable. Its second Z homology class is zero. It has no fundamental class over Z. No Klein bottle embedded in a larger manifold can ever represent a Z-cycle.
Another example is the projective plane. It has no fundamental cycle over Z.
WWGD said:
Excellent. Very clear, thanks.
If you use Z/2 instead of Z as homology coefficients then non-orientable manifolds do have a fundamental cycle. They will represent Z/2 homology classes in you larger manifold.
Thanks again, Wofsy, all .
Is there a geometric way of seeing/understanding these cycles?. I am trying
to understand this fundamental class in a more geometric way. Say we
take the example of the circle, so that we get H_1(S^1)=Z . What would
[S^1] look like geometrically?
I imagine that
at least within what may be the simplest homologies, singular and simplicial, cycles
can be seen as maps (maybe identified with their images, i.e., if f: sn -->X is
a cycle, with sn an n-simplex , then f(sn)<X can be seen as a cycle) .
Then, as I understand it , at least in simplicial homology, two cycles in X are
homologous if their (point set) sum is a boundary for X , in the sense that if we
remove f(sn) from X, we get a disconnected space. I am thinking here of the
example of the torus, where a closed curve that is not longitudinal nor latitudinal ,
seen as a closed curve on the surface of the torus is a boundary , and any two
latitudinal or any two longitudianl curves are boundaries, since their point-set
sum ( i.e., the union of their images) is a boundary in the sense above ( i.e.,the re
moval will disconnect the space )
Can this geometric idea of cycles be extended to other homologies? .
Thanks.
[S^1] look like geometrically?I imagine that
Can this geometric idea of cycles be extended to other homologies? . Thanks.
There is no simple answer to your question but here are a few thoughts.You can think of a one dimensional cycle as a finite collection of closed curves. Intuitively it is homologous to zero if it is the curves are the boundary of a two dimensional region.
For instance on the torus ,as you wrote, a curve that loops around or through the ring will not be a boundary of a 2 dimensional region but a small circle that does not loop around will be the boundary of a disk.
However general closed curves can be wild and not be the boundary of any region even if they are homologous to zero. For an extreme example think of a closed space filling curve on the sphere. It is homologous to zero. can you picture it as a boundary?
A good example is the annulus. All closed curves, no matter how wild, wind around the annulus a certain number of times. The number of windings is its homology class.
In complex analysis the number of windings can be measured by taking the line integral of a branch of the logarithm along the curve (assuming that it is piecewise differentiable). No matter what the curve, this integral will be an integer multiple of 2 pi and is the total angle that the curve traces around the center of the annulus. This integer is called the winding number of the curve. If I wind around twice then I integrate twice and get twice the winding number. If I wind backwards I get negative the integral and negative the winding number. Two curves are homologous if the integral of the log is the same. A curve is homologous to zero if the integral of the log is zero.
I believe that the idea of homology began with this example because people realized that line integrals of holomorphic functions depend only on the homology of the curve and not on the specific path that it traverses. A function that is holomorphic in some region of the plane (possibly with many holes in it) will have integrals that depend only on the number of times that the curve winds around the holes. This winding count is the homology class of the curve.
These ideas extend naturally to Riemann surfaces and the study of integrals of meromorphic functions on Riemann surfaces reveals that there are more complicated ways that curves can wind around than just winding around holes. But the same principle holds.
For the circle, curves are classified also by the number of times they wind around. A fundamental cycle is any curve that winds around once. This is really the same situation as the annulus.
The reason cycles are thought of as mappings is that the geometric image does not tell you the number of times that the curve winds around and thus does not tell you the homology class.
WWGD said:
I am trying
Suppose you have a closed oriented manifold M and a simplical structure on M. A cycle representing the fundamental class is obtained as the sum of all the the top-dimensional simplices, assuming they have the same orientation as the manifold (otherwise there are signs).
I don't mean to beat these questions to death, it is just that these answers really help me
tie down a lot of loose ideas I have (which may be natural to have in one's first year).
Please ignore them if it is too much. I really do appreciate all your comments:
I see, so the region is simply-connected iff every closed curve (and therefore every cycle)
So I guess log is defined in the region R whenever the winding number about a point
not in R is zero. Then the integral dz/z is zero , and so it is independent of path, which
I understand to be equivalent to the log being defined/definable, i.e., that the integral
of dz/z around any curve is zero, and so is independent of path.
But there seems to be an issue of homotopy here too, right?. If curves C_1, C_2 contained
in R have the same winding number about points in C-R , and (it follows that )C_1 and C_2 are homotopic, and the homotopy takes place entirely in R (I think this property has the weird name of R being "semilocally simply-connected" ), then, for any f holomorphic in the region we have:
Int_C_1 f(z)dz =Int_C_2 f(z)dz
To Wofsy: A followup on a question you had asked; I forgot on which post, about
uniqueness of smooth structures for dimensions less than or equal to 3. Here are
the refs:
i) E. Moise: "Geometric Topology in Dimensions 2 and 3". Springer-Verlag, N.Y, 1977
ii) J. Munkres " Obstructions to the smoothing of piecewise differentiable
homeomorphisms." Annals of Math., 72:521-554 , 1960.
Wofsy:
"There is no simple answer to your question but here are a few thoughts.
In complex analysis the number of windings can be measured by taking the line integral of a branch of the logarithm along the curve (assuming that it is piecewise differentiable). No matter what the curve, this integral will be an integer multiple of 2 pi and is the total angle that the curve traces around the center of the annulus. This integer is called the winding number of the curve. If I wind around twice then I integrate twice and get twice the winding number. If I wind backwards I get negative the integral and negative the winding number. Two curves are homologous if the integral of the log is the same. A curve is homologous to zero if the integral of the log is zero."
Wofsy Wrote:
"I believe that the idea of homology began with this example because people realized that line integrals of holomorphic functions depend only on the homology of the curve and not on the specific path that it traverses. A function that is holomorphic in some region of the plane (possibly with many holes in it) will have integrals that depend only on the number of times that the curve winds around the holes. This winding count is the homology class of the curve."
the refs:
WWGD said:
Wofsy:
I have to apologise. I mispoke about the log. The winding number is defined by the integral of dz/z-a where a is chosen in the center of the annulus. This integral's value is the difference in the two values of the log as the curve winds on its Riemann surface. dz/z-a is holomorphic in the annulus.
Second. Homotopy and homology are not the same. While it is true that a region of the plane is simply connected iff its first Z homology is zero there are spaces where this is not true. Further, in the plane some regions do not have an abelian fundamental group. In these regions number of times a curve winds around the holes does not determine the homotopy class. It is also the order in which it winds around the holes. In homology the order doesn't matter. Notice that the order doesn't matter for line integrals either.
