Surfaces/Areas of Revolution - Parametric
  • Context: Undergrad
  • Thread starter Thread starter KingBongo
    Parametric Revolution
The discussion centers on calculating the surface and volume of revolution for a parametric curve defined by x = f(t) and y = g(t) over the interval a ≤ t ≤ b. The formulas presented are S = 2π∫ |g(t)|√((df(t)/dt)² + (dg(t)/dt)²) dt from t=a to b for surface area and V = π∫ (g(t))²(df(t)/dt) dt from t=a to b for volume. Key considerations include the behavior of the curve, specifically whether df(t)/dt remains non-negative and the implications of the curve crossing quadrants. The user seeks to minimize surface area while maintaining a constant volume, with specific end conditions for the parametric functions.
  • Understanding of parametric equations and their derivatives
  • Knowledge of calculus, specifically integration techniques
  • Familiarity with the concepts of surface area and volume of revolution
  • Experience with optimization problems in calculus
  • Study the implications of parametric curves crossing quadrants on surface and volume calculations
  • Explore optimization techniques for minimizing surface area while maintaining constant volume
  • Investigate the conditions under which df(t)/dt must be non-negative for valid results
  • Learn about the application of Lagrange multipliers in constrained optimization problems
Mathematicians, engineering students, and anyone involved in calculus, particularly those focusing on parametric equations and optimization in geometric contexts.
KingBongo
Suppose that you have a parametric curve given by
x = f(t), y = g(t), a ≤ t ≤ b
What will the Surface of revolution and Volume of revolution around the x-axis be?
I have two candidates:
Surface: S = 2*pi*int( |g(t)|*sqrt( (df(t)/dt)^2+(dg(t)/dt)^2 ) , t=a..b)
Volume: V = pi*int( (g(t))^2*df(t)/dt , t=a..b)
I believe those are correct, at least I hope so... Now, here come my main questions;
1. Under what circumstances will you get "correct" results? Under what circumstances does the surface/volume "overlap" when rotating?
2. Does the curve have to behave in some certain way? Does it have to stay in one quadrant for all t? Do you have to impose some conditions, like df(t)/dt≥0 for all t?
Could somebody please explain this to me? I have been trying to figuring that out.
Number two gives you the big hint
What if df/dt<0 for some t? Then the x coordinate will double back on itself... but you don't know what happens with the y coordinate. So your curve isn't the curve of a function (since it's multi-valued). Try drawing some curves like that and see if anything gets messed up
Office_Shredder:
Yes, that is another possiblity, :) Mine was only an example. What I am looking for is what happens when the curve "turns" back in one or more of the coordinates and when it exists in more than one quadrants and stuff like that. Anything that can go wrong. That is why I am asking these questions.
Man, is this some kind of joke or what?
I am trying to find a parametric curve, x=f(t) and y=g(t), preferably lying in the first quadrant (x≥0, y≥0), fulfilling all of the objectives
A. Minimizing the surface of revolution around the x-axis, min S
B. Constant volume of revolution around the x-axis, V=const
C. End conditions f(a)=0, g(a)=R, g(b)=r, where R≥0, r≥0
In my mind this should be solvable, ending up with some kind of round curve (possibly part of a circle), but I am not able to find any feasible Extremals.
WHAT is wrong here? Does anybody have any idea? Are my formulas for the surface of revolution and volume of revolution correct?
