Synchronized clocks with respect to rest frame
  • Level: Graduate
  • Thread starter Thread starter mananvpanchal
    Clocks Frame Rest
130 replies · 23K views · last reply
John232 said:
I thought one of the postulates of SR is that on object in constant motion can't distingiush between that and being at rest. It would seem like that if A and B could be measured to not be in sync with O from O, then O could then conclude that it was in fact in motion. So then, only R could conclude that the clocks where not in sync but O would conclude that they are. This would be because O would measure the speed of light to be the same forwards and backwards through the train since it assumes it is at rest, and R concludes that the light traveling to the back of the train from O reaches first, since it observes the speed of light to be the same in both directions, but the velocity of the train itselfs shortens the distance it has to travel. But, does this actually puts the clocks out of sync from the frame of reference of R? All three clocks would have been seen from the frame of reference of R to all have gone the same speed that should calculate into them expereincing the same amount of time dialation. All it would meen is that a signal seen from R from O would hit A and B at different times. It would seem like each side of an object shouldn't experience different amounts of time dialation. I think it only means that a signal form O seen from R would reach A and B at two different times, but the clocks themselves would be in sync if you could check using some sort of action at a distance.
Thank you very much John232.
This is what exactly I want to describe. Somehow I could not explain myself.
One way speed of light is same for all, then clocks is synchronized with respect to O. And if R can see the clocks by sending light pulse. R can also conclude that the both clock is synchronized with each other, but the clocks is behind of his own clock due to time dilation.
mananvpanchal said:
Now, train starts moving to right. It accelerate and after some time it runs with constant speed. Now, the clock is still synchronized with respect to O.
But what about R? Is clocks synchronized with respect to R? If no, then which clock is ahead A or B?
But O isn't in constant motion, O accelerates. That acceleration is detectable in multiple ways, including the desynchronization of A and B.
DaleSpam said:
Nonsense. Exactly how many lines are required for a sufficient treatment? What if I set Einstein's treatment in a larger font with a narrower column width so that it takes the required number of lines, does the treatment suddenly become sufficient?
ah ha ha, reading this thread was worth that laugh.
I'm learning about "debate logic", AdrianMay you should do the same. The comment "Four lines. Hardly a sufficient treatment." I'd class as non-sequitor (lines of text has nothing to do with suffucient treatment") &/or it begs the question. I'm not too sure just learning still.
Thanks nitsuj. I like this site for learning about logical fallacies:
http://www.fallacyfiles.org/
I agree with your classification as a non-sequitor. The fallacyfiles site calls it the "red herring" fallacy.
I wouldn't classify it as begging the question because begging the question means that the conclusion (Einstein's treatment is insufficient) is contained in the premises (Einstein's treatment is 4 lines long) or that the argument assumes some point not conceded by the other side (I concede the length of the treatment). In this case, the conclusion is not contained in the premise and the premise is not controversial in the discussion, it is simply that the premise (length) is completely irrelevant to the conclusion (sufficiency).
I don't recal ever hearing that clocks that accelerated together at the same rate would ever no longer be synchronized. Thinking back to the Einstein in the elevator thought experiment, I thought, what if he had a stepladder. Could he move up the step ladder and find that his light ray bends by a different amount? I think no at each step, but yes as he moved up the steps. Then what if he did the same experiment at Earth? Closer to the Earth the beam would bend more, since it would have a stronger gravitational pull. If he moved farther away from the Earth it would bend less being farther away from the planet.
The trains acceleration, unlike Earths gravitational pull, would act equally on the whole train if it was rigid.
Hello,
The below images show O's accelerating motion with respect to R. As speed changes desynchronization becomes bigger with respect to R.
Please, look at first frame of below image. It shows desynchronization of clocks when frame is in motion. But, it is with respect to R.
Diagram of a red lattice truss drawn on coordinate axes, bending upward in a curve across several parallel copies, with a 'DEMO VERSION - PLEASE ORDER FULL VERSION' watermark stamp.
When we transform to first frame, as below image shows there is no longer desynchronization with respect to O. But, second frame is desynchronized with respect to O.
Red line diagram of a worldline-style grid: a vertical axis with a red lattice of slanted lines that bends and tilts to the right as it rises, with a DEMO VERSION watermark stamp in the lower right.
But, again we transform to second frame. there is no longer desynchronization with respect to O. But, first frame is desynchronized with respect to O.
Red zigzag diagram of a worldline-style lattice of clock-synchronization lines on axes, with a 'DEMO VERSION' watermark stamp over the lower right.
So, desynchronization is only there when we see other frame. Our own frame cannot have desynchronization with respect to itself.
So, as I understand constant speed of frame would not create desynchronization, and changing in frame (acceleration) also would not create desynchronization.
Can you explain me how acceleration can create desynchronization with respect to O?
In an inertial frame this is correct. Two clocks which are initially synchronized and share the same speed profile will remain synchronized, but only in that inertial frame.
In other inertial frames or in non inertial frames they will not be synchronized. O's frame is non inertial.
|mananvpanchal first post (with quotation marks) and my comments without quotation marks.
"Suppose, A and B is clocks at both end of train. A is at left and B is at right. Observer O is at middle of train at point M. Observer R is on platform.Train is at rest and O synchronize both clock. The clock is synchronized with respect to both observer."
clocks are synchronized.
"Now, train starts moving to right. It accelerate and after some time it runs with constant speed. Now, the clock is still synchronized with respect to O."
At the point that the entire train is again inertial, yes the clocks, tell the same time as O and O confirms this as being true.
During acceleration A clock will appear to run behind O and B will appear to run ahead of O WRT the inertial synchronization (also B will appear larger and A will appear smaller -very minutely during acceleration).The aberration in time measurement during acceleration corrects itself when the object returns to an inertial state- there is no measurable difference in the clocks after the train return to an inertial state.
"But what about R? Is clocks synchronized with respect to R? If no, then which clock is ahead A or B?"
Clearly The clock of R will be running faster than A and B and O and continue to run at the same faster rate with the train again inertial. From the moment the train started moving WRT R, the clock of R was not synchronized with the clocks on the train.
"Thanks."
I hope this answers your question.
mathal
There is other doubt too.
second image of post #36 says clocks is synchronized with respect to O, but not for R. For R clock A is ahead of clock B, because signal reaches lately to B with respect to R because of direction of motion.
Suppose, that train is coming from far left of R, it passes R and goes far right with constant velocity. So below image show how clocks becomes desync with respect to R. It also tells train coming from left and goes right not make changes in desync. A is always ahead of B with respect to R during whole journey.
Diagram of a family of parallel red lines slanting up to the right, joined by short red rungs forming a zigzag ladder pattern, drawn on axes with a watermark reading DEMO VERSION.
But, wait if we think how R sees clocks during whole journey. Below image show that
Spacetime diagram with red lines forming a tilted grid of slanted and horizontal lines, with an x axis at the bottom and a vertical time axis, partly covered by a 'DEMO VERSION' watermark stamp.
There is matter that train coming from left and goes to right. Coming from left tells R that clock B is ahead of A, and going right tells R that clock A is ahead of B.
Look, at the point where R and O is on perpendicular line of train path way. This is the point where R thinks both clock is synchronized.
From my understanding, first image shows that "R thinks that clocks would be desynchronized like this with respect to O". Neither for R the clocks would be desynchronized like this, nor for O.
What I understand is clocks is perfectly synchronized for O and, clocks is desyhnchonized with respect to R as showed in second image.
Can anyone shade some light on this?
Thanks
I fail to see how that is true without an explanation. For instance, how does the relation of the distance of two objects make them observered from rest as measuring time differently when they have accelerated the same amount for the same duration? I think the proof in the pudding here would be that if you considered each object separately you would find that they both expereince the same amount of time dialation, but if you considered them together or linked to an action they would be seen to experience different amounts of time dialation. So, then why would an object require different amounts of spacetime dilation if it was seen to travel at the same speed of another object in order to measure the same speed for light? It would make it seem that the origanal answer of the amount of spacetime dilation occurred for each object would be false unless you considered your own relation to the object. Then answers that considered your relation to the object would not be interchangeable with answers that didn't consider your relation to the object, since they would give different values. Then if the object is traveling with a velocity then would the amount of spacetime dilation that occurred change as it moved to a different location? Then the whole thing falls apart, none of the results would give the same speed of light or the same amount of time dilation if it was considered to be X units away from something else, and that affect the outcome of the amount of spacetime dilation that occurred.
For each velocity, there could only exist one distortion of spacetime that would conclude that there is the same value for the speed of light. For instance, two people traveling together on a train couldn't be seen to measure time differently because then they would each have different values of the speed of light. Their location as being in the front or back of the train doesn't affect how they can make that measurement. The basis of SR is that the speed of light is constant in all frames. I think clocks should only be checked if they are synchronized using an entanglement experiment, something Einstein never would have done because nothing was supposed to travel faster than the speed of light at the time.
When I posted my responce I edited myself twice- and I'm still not satisfied with what I wrote. It all boils down to the measurement problem.
If there are only 2 clocks held by A and B then while the train is inertial O will observe the same time on both clocks.
For instance if the train is dark inside and the clocks flash seconds the signals will reach O at the same moment. If O uses a flash of light to see each clock the images will show the same time.
During acceleration things are different.
Using flashing clocks the signal from A is traveling to O who is accelerating away from this flash and so will receive it later than the flash from B which is approaching him as he accelerates towards it. The impression this gives is that A clock is lagging behind B clock.
The observation when O uses flashes of light towards A and B clocks is the opposite. His flash arrives later to B then it does to A. The picture of the clock times gives the impression that A clock is running faster than B clock. (tic) The images of the clocks will arrive back to O at the same moment.
If the acceleration is constant there will be a constant lag time.
Simultaneous identical acceleration of two clocks does not break the synchronization.
mathal
Certainly, it follows directly from the Lorentz transform. Let's analyze the scenario from the OP where at t=0 in the original frame A, B, and M all accelerate instantaneously up to v = .6c and furthermore let's use units where c=1 and where the distance from M to A and from M to B is 1 in the original frame.
So, in R's frame the worldline of A, O, and B are:
[tex]r_d=\left(t,x=\begin{cases}<br /> d & \mbox{if } t \lt 0 \\<br /> 0.6 t+d & \mbox{if } t \ge 0 <br /> \end{cases}<br /> ,0,0\right)[/tex]
where d=-1 for A, d=0 for O, and d=1 for B.
As per the OP, the clocks are initially synchronized in R's frame such that at t=0 they all read 0. So, we can calculate the time displayed on each clock, τ, using the spacetime interval. Solving for t we get:
[tex]t=\begin{cases}<br /> \tau & \mbox{if } \tau \lt 0 \\<br /> 1.25 \tau & \mbox{if } \tau \ge 0 <br /> \end{cases}[/tex]
Substituting into the above we get:
[tex]r_d=\left(<br /> t=\begin{cases}<br /> \tau & \mbox{if } \tau \lt 0 \\<br /> 1.25 \tau & \mbox{if } \tau \ge 0 <br /> \end{cases},<br /> x=\begin{cases}<br /> d & \mbox{if } \tau \lt 0 \\<br /> 0.75 \tau+d & \mbox{if } \tau \ge 0 <br /> \end{cases}<br /> ,0,0\right)[/tex]
Noting that τ does not depend on d in this frame we see immediately that the clocks remain synchronized in R's frame.
Now, boosting to the primed frame where O is at rest for τ=t>0, we obtain.
[tex]r'_d=\left(<br /> t'=\begin{cases}<br /> 1.25 \tau - 0.75 d & \mbox{if } \tau \lt 0 \\<br /> \tau - 0.75 d & \mbox{if } \tau \ge 0 <br /> \end{cases},<br /> x'=\begin{cases}<br /> 1.25 d - 0.75 \tau & \mbox{if } \tau \lt 0 \\<br /> 1.25 d & \mbox{if } \tau \ge 0 <br /> \end{cases}<br /> ,0,0\right)[/tex]
Noting that τ does depend on d in this frame we see immediately that the clocks are desynchronized in O's frame. If there is some step that you do not follow then please ask for clarification. But it is quite clear the the clocks remain synchronized in the unprimed frame and are not synchronized in the primed frame.
Thanks for your reply.
DaleSpam said:
1. [itex]r_d=\left(t,x=\begin{cases}<br /> d & \mbox{if } t \lt 0 \\<br /> 0.6 t+d & \mbox{if } t \ge 0 <br /> \end{cases}<br /> ,0,0\right)[/itex]
2. [itex]t=\begin{cases}<br /> \tau & \mbox{if } \tau \lt 0 \\<br /> 1.25 \tau & \mbox{if } \tau \ge 0 <br /> \end{cases}[/itex]
3. [itex]r_d=\left(<br /> t=\begin{cases}<br /> \tau & \mbox{if } \tau \lt 0 \\<br /> 1.25 \tau & \mbox{if } \tau \ge 0 <br /> \end{cases},<br /> x=\begin{cases}<br /> d & \mbox{if } \tau \lt 0 \\<br /> 0.75 \tau+d & \mbox{if } \tau \ge 0 <br /> \end{cases}<br /> ,0,0\right)[/itex]
I follow this.
4. [itex]r'_d=\left(<br /> t'=\begin{cases}<br /> 1.25 \tau - 0.75 d & \mbox{if } \tau \lt 0 \\<br /> \tau - 0.75 d & \mbox{if } \tau \ge 0 <br /> \end{cases},<br /> x'=\begin{cases}<br /> 1.25 d - 0.75 \tau & \mbox{if } \tau \lt 0 \\<br /> 1.25 d & \mbox{if } \tau \ge 0 <br /> \end{cases}<br /> ,0,0\right)[/itex]
But I don't follow this. I have tried to get it, but I don't succeed. That's fine, don't worry about it.
From 1st equation the calculation is done considering speed 0.6c.
So, you are trying to say is:
at t < 0, clocks is synchronized for both R and O. And at t = 0 train changes its frame and travels at 0.6c, and at t=0 the clocks becomes desynchronized for O.
Whatever you stated before you state same here with maths.
Actually, I like maths, but, equations comes from theory. It state same thing as theory states. I need to understand the theory first.
Actually I need be explained that how clocks becomes desynchronized for O, when train changes its frame.
Please, shade some light on my post #36 and #39. Please, tell me what is wrong with my understanding.
Thanks again DaleSpam.
Thanks mathal
mathal
That is what I think. Constant speed cannot affect synchronization. And simultaneous identical acceleration creates constant deference between clocks. As soon as the speed becomes constant the clocks again becomes synchronized.
Looks to me like you rigged the equations to give different values for A, O, and B from the intitial setup of the first equation. Say for instance instead, I used different equations like the time dilation equation. Then I solved for A, O, and B. I would get the same answer for each one that would end up getting me different values than what you got...
This would be because d has different values for A, O, and B. If I simply put the values of A in the time dilation equation it would have the same values for O and B, so then I would know that they should all come out to be the same since they had the same value for t and v. Distance wouldn't be an issue in my setup. I don't think it should since the distance the objects are away from each other wouldn't affect how they measured the speed of light...
There is more to relativity than just time dilation. The Lorentz transform is more general and automatically reduces to the time dilation formula whenever appropriate. I recommend against ever using the time dilation formula. It will cause mistakes, as this example would show.
So, using the matrix form of the Lorentz transform we have:
[tex]r'_d=\Lambda \cdot r_d = \left(<br /> \begin{array}{cccc}<br /> 1.25 & -0.75 & 0 & 0 \\<br /> -0.75 & 1.25 & 0 & 0 \\<br /> 0 & 0 & 1 & 0 \\<br /> 0 & 0 & 0 & 1<br /> \end{array}<br /> \right) \cdot \left(<br /> \begin{array}{c}<br /> t = \begin{cases}<br /> \tau & \mbox{if } \tau \lt 0 \\<br /> 1.25 \tau & \mbox{if } \tau \ge 0 <br /> \end{cases} \\<br /> x = \begin{cases}<br /> d & \mbox{if } \tau \lt 0 \\<br /> 0.75 \tau+d & \mbox{if } \tau \ge 0 <br /> \end{cases}<br /> \\<br /> 0 \\<br /> 0<br /> \end{array}<br /> \right)[/tex]
[tex]r'_d=\left(<br /> \begin{array}{c}<br /> t'= -0.75 \begin{cases}<br /> d & \mbox{if } \tau \lt 0 \\<br /> 0.75 \tau+d & \mbox{if } \tau \ge 0 <br /> \end{cases}<br /> + 1.25 \begin{cases}<br /> \tau & \mbox{if } \tau \lt 0 \\<br /> 1.25 \tau & \mbox{if } \tau \ge 0 <br /> \end{cases} \\<br /> x'=<br /> 1.25 \begin{cases}<br /> d & \mbox{if } \tau \lt 0 \\<br /> 0.75 \tau+d & \mbox{if } \tau \ge 0 <br /> \end{cases}<br /> - 0.75 \begin{cases}<br /> \tau & \mbox{if } \tau \lt 0 \\<br /> 1.25 \tau & \mbox{if } \tau \ge 0 <br /> \end{cases} \\<br /> 0 \\<br /> 0<br /> \end{array}<br /> \right)[/tex]
If you go back to your #36 and #39, you can see that you have identified some events on A and B which are identified as being simultaneous for O.
What you have not done is indicate what the clocks at A and B read at those events. However, if you look at the length of the line from the bend, when the clocks all read 0, to the events in question you will see that they are different lengths.
Therefore A and B will not read the same at those events. They will therefore be desynchronized according to O.
Thats like saying Lorentz was the real genius and Einstein was a dumb***. I went to the wiki and in the fine print under the first diagram to the right it says that it describes when one event detects another event. So then any result useing that equation would only tell what each observer see's when they detect an event. So that doesn't mean that A and B are no longer in sync it only means that the signal to R is not in sync. I wouldn't use the Lorentz Transform to ever find out any information about what clocks say to determine the amount of time dilation from one frame of reference to another, or you would always be wrong, since your just finding out what an observer detects at a certain moment.
:rolleyes: Clearly that is an absurd mischaracterization of what I said.
John232 said:
I went to the wiki and in the fine print under the first diagram to the right it says that it describes when one event detects another event. So then ...
Please link to the page in question. You have a definite misunderstanding of relativity and the Lorentz transform, but I am not sure why.
Alternatively, feel free to actually work through the problem mathematically using whatever approach you prefer, and then post your work. If you get a different result then I will gladly help you see where you went wrong.
If we have a long object such as a rocket with initially synchronised clocks at the tail and nose and accelerate the rocket, the clock at the tail travels a further distance than the clock at the front of the rocket in a given time as measured in the original rest frame. This causes the clocks become unsynchronised in the rest frame of the rocket as the rear clock effectively has to travel faster (in the original frame) and time dilates to a greater extent. This is because in order for the rocket to retain its proper length in the rest frame of the accelerating rocket, it is length contracting in the original frame. THis form of acceleration is known as Born rigid acceleration (See http://www.mathpages.com/home/kmath422/kmath422.htm or Google Bell's rocket paradox). The clocks will remain synchronised (in the launch frame) under acceleration if we insist the clocks remain the same distance apart in the launch frame, but under these conditions the the rocket will be increasing its proper length and eventually be torn apart. Even under these conditions, the clocks will be unsychronised in the rest frame of the accelerating rocket because the rocket has a velocity relative to the launch frame and the relativity of simultaneity means that if the clocks appear synchronised in the launch frame they will not be synchronised in the accelerating rocket frame.
Sorry for the layman's sloppy explanation but I think that is the gist of it ;)
As we get the equation below
We can see that [itex]t'=\tau - 0.75 d, \mbox{if } \tau \ge 0[/itex]. And we know that d=-1 for A, d=0 for O and d=1 for B then, we can get this
[itex]t'_a=\tau + 0.75,[/itex]
[itex]t'_o=\tau,[/itex]
[itex]t'_b=\tau - 0.75[/itex]
But suppose, train is going to opposite direction, then the equation cannot distinguish both [itex]t'[/itex]. We get same values for A and B for both direction, if A is ahead in one direction, A will be ahead in other direction too. The equations is depend on [itex]\tau[/itex], and [itex]\tau[/itex] is not depend on [itex]x[/itex]. [itex]\tau[/itex] is just time dilation, in whatever direction the train is going
But, there must be meaning of direction of motion.
What clock is ahead of other is matter of method used for reading, as mathal and I said before. But using anyone method, the result should be opposite if direction of motion is opposite. If A is ahead in one direction, then B must be ahead in opposite direction.
So, far We get only one reason for desynchronization is "length contraction".
The above image shows that train has length of l1 at start X, train accelerated to Y point, at that time length becomes l2. From now Y to Z train maintains its constant velocity, so now length remain same as l2. llxy, lrxy, llyz and lryz is distance traveled by front and end point of train.
We can easily see that ratio between llxy and lrxy is more than llyz and lryz.
So, as train maintains its constant velocity for longer time the desynchronization created by length contraction decreases.
If we guess that one way speed of light is not same in all direction then we have now another reason to explain desynchronization on frame change. Like, light takes more time to reach to observer in direction of motion and less time in opposite direction. But, in this idea direction of motion matters. If we change direction of motion A and B changes its state of desynchronization.
But, we cannot say one way speed of light is not same in all direction.
And we cannot say change in frame cannot affect synchronization.
May be anyone we have to pick.
"with respect to O" described in post #36. Actually I have identified all events as being simultaneous for O.
Actually, I want to say with this three images that all events is simultaneous for O.
Ok, please look at second and third image.
In second image O is currently in first frame. Second frame is also O's frame, but second frame is future of O. O sees that all events in first frame is simultaneous for him. If somehow O could see second frame, O can conclude that in second frame events will not be simultaneous for him. Now, O changes his frame, if we want to look actual scenario, we have to transform from first frame to second frame. To show transformation I converted second image to third image. Now, please look at third image. Again O sees in second frame all events is simultaneous for him. If somehow O could see his first frame, O can conclude that events would not be simultaneous for him in first frame.
So, conclusion is if current frame is inertial then all events would be simultaneous for O. When frame is changed, some desynchronization occurs if this case happens. Suppose, O have fires pulses in both direction. O changes his frame in mean time before the pulses reach to the clock-mirror. In that case desynchronization created. But it will be for just that one pulse firing. Now, O again in inertial frame. Now O fires pulses, O feels clocks is synchronized again.
The equation was derived specifically for the scenario represented in the OP. It is not a general equation and cannot be used as is to make any conclusions about other scenarios. Any reasoning based on using this equation for a different scenario is inherently flawed.
If you want to generalize it then you are certainly welcome to. You would need to use an arbitrary velocity, v, instead of 0.6 c as I used here. Then your more general expression would reduce to these equations for v = 0.6 c and would reduce to the equations for the train going the opposite direction for v = -0.6 c.
I have proven beyond any doubt that the clocks are desynchronized after t=τ=0 for the scenario in the OP. Do you understand and agree with that?
I am not sure what you are trying to say here. Not all events are simultaneous for O, for example no two distinct events on O's worldline are simultaneous.
It would help greatly if you would label different specific events on the worldlines and calculate the spacetime coordinates in the given frame and what the clocks read at those events. Then we can communicate clearly about your drawings.
I am very sorry about this. Sometimes mind works like crazy. Discussion is going on here about O and I am talking about "with respect to R" in this paragraph.
It was the same page that you gave a link to when you put the equation on the forum to begin with. I think you have a clear misunderstanding of the difference between the actual time dilation and the observed time from a location, and that is why when you end up using the time dilation formula you always end up getting answers that are "wrong".
I don't think it is that hard to see that if two locations in an object are seen to travel at the same speed that they would have to expereince the same amount of time dialation, and they are just observed by an outside observer to be out of sync. I just don't know what else to tell ya, besides maybe that if you insist on only using that equation, I agree you shouldn't ever just use the time dilation equation alone without it...
But due to the relativity of simultaneity that is only the case in R's frame. In all other frames the objects do not travel at the same speed at all times, therefore they do not experience the same amount of time dilation and they become desynchronized.
Yes, you are right. We will get the answer as you said.
There is another doubt!
This may be the case again of generalization.
As [itex]\tau[/itex] increases, desynchronization between two clocks decreases.
So, for [itex]\tau < 0[/itex], all clocks are synchronized. At [itex]\tau = 0[/itex] train changes its frame, and starts moving with constant speed 0.6c, the clocks is most desynchronized. For [itex]\tau > 0[/itex], as [itex]\tau[/itex] increases, desynchronization between two clocks becomes less and less. And after much more time, there is very negligible amount of desynchronization remains with respect to O.
Please, explain me how can we solve this?
