System of coupled second order differential equations.
The discussion focuses on finding the characteristic equation for a system of coupled second-order differential equations represented as \(\ddot{x} + A\dot{y} + Bx = 0\) and \(\ddot{y} + C\dot{x} + Dy = 0\). The method proposed involves converting the second-order system into a first-order system by defining new variables \(x_1 = x\) and \(y_1 = y\), leading to a 4x4 matrix formulation. The characteristic polynomial derived from this transformation is \((D^2+B)(D^2+E)-ACD^2\), resulting in \(D^4+(B+E-AC)D^2+BE\). This approach effectively identifies the eigenvalues necessary for solving the system.
  • Understanding of second-order differential equations
  • Familiarity with matrix algebra and eigenvalues
  • Knowledge of converting higher-order systems to first-order systems
  • Basic proficiency in differential calculus
  • Study methods for converting second-order differential equations to first-order systems
  • Learn about eigenvalue problems in linear algebra
  • Explore characteristic polynomials and their applications in differential equations
  • Investigate numerical methods for solving coupled differential equations
Mathematicians, engineers, and students studying differential equations, particularly those working with coupled systems and seeking to understand eigenvalue methods for solving such equations.
Deadstar
Hey folks I'm looking for a way to find the characteristic equation for a second order coupled system of differential equations such as...
Where x and y are functions of time.
I know I can solve it by setting x and y to standard results (trig, exponential) but I'd like to know a method to solving this rather than plug and solve for coefficients.
Specifically I'd like to know how to find the characteristic equation for this. I've tried setting it to a first order system but I can't see it leading anywhere (or perhaps I just did it wrong...).
I don't want a full answer, just the name of a method or something like that.
Actually I think I've got it...
Setting x_1 = x, y_1 = y, then converting into four first order differential equations. Find eigenvalues of 4x4 matrix etc... Think that's it.
It's not entirely clear what you did other than add a subscript to x and y, but I suspect you have the right approach.
rewrite the system (I will use E for your D and D for differentiation)
(D^2+B)x+(AD)y=0
(CD)x+(D^2+E)y=0
then the characteristic polynomial is
(D^2+B)(D^2+E)-ACD^2=
D^4+(B+E-AC)D^2+BE
as expected.
  • · Replies 27 ·
