System of Differential equations with a singular coefficient matrix, help?
The discussion revolves around solving a system of differential equations with a singular coefficient matrix, specifically using the matrix A = [[-2, 1], [-1, 0]]. The original poster struggles with finding a complete solution due to having only one eigenvector and attempts to use undetermined coefficients. Suggestions include utilizing the matrix exponential and reducing A to Jordan form for a more comprehensive solution. Additionally, it is noted that initial conditions can help determine coefficients in the solution, and finding both eigenvalues and eigenvectors is crucial for solving the system effectively. The conversation emphasizes the importance of linear algebraic methods in addressing such differential equations.
aeroegnr
I tried using undetermined coefficients to solve this problem, but I know that I am missing something and i cannot find any reference material on this. If you help me, thank you.
The homogeneous equation for the system is:
y' = A*y
where y = \left[ \begin{array}{c} y_1 \\ y_2 \end{array} \right]
and A = \left[ \begin{array}{cc} -2 & 1 \\ -1 & 0 \end{array} \right]
I end up with only one eigenvector of course, and I'm trying to use a solution that ends up as C1*V*e^t + c2*V*t*e^t where V is the only eigenvector of A, but that is not a complete solution.
What am I missing?
I suppose there is a general way to solve this type of linear constant coefficient differential equations.
I suppose you mean A is not diagonalisable? But A can always be reduced to a matrix in Jordan form. Do you know what is "matrix exponential"? The "fundamental solution" of the system is given by exp(tA). (The fundamental solution is a matrix whose columns are solutions of the system and linearly independent.) When A is reduced to a matrix in Jordan form, the "matrix exponential" is readily computable. So I think that is the solution you want?
And I think there is a way to solve this without using Jordan form? your equation reads
y1'=-2*y1+y2
y2'=-y1
That is
y1''=-2*y1'+y2'=-2*y1'-y1
which is readily solvable. From this you might obtain two independent solutions. Plug them into the other equation to obtain the solution to the system.
I found out what the problem was, I had to create a new vector U instead of just using V.
Thanks Wong, but I'm taking an advanced math class where they are teaching us how to use linear algebraic methods to solve differential equations.
y' = A*y
What am I missing?
Initial conditions perhaps?
initital condition only solve for coefficient of the Y solution. like his c1, c2
first find ur eigenvalues then find ur eigenvectors and use that egeinvector in the Y solution.
