Understanding Solutions to Systems of Linear Equations
The discussion revolves around solving a system of linear equations represented by a matrix. The equations derived from the matrix indicate that x must be 0, which leads to y also being 0, leaving z as the free variable. Participants explore different approaches to identify free variables, with some suggesting that either x or y can be treated as free variables depending on the context. The confusion arises in determining which variable to choose as free, highlighting the need for clarity in understanding the relationships between the variables. Ultimately, the key takeaway is recognizing that z is the only free variable in this specific system.
roam
This is from a solved problem:
Here is a system:
\begin{bmatrix} {1 & 0&0 \\ -1&0&0\\3&-5&0 \end{bmatrix} \begin{bmatrix} {x \\ y\\z \end{bmatrix}= \begin{bmatrix} {0\\ 0\\0\end{bmatrix}
A general solution of this system is
x= \begin{bmatrix} {0 \\ 0\\t \end{bmatrix}= \begin{bmatrix} {0 \\ 0\\1 \end{bmatrix} t
So, how did they get this solution? I tried solving this and I just don't get it!
The matrix corresponds to the set of equations:
x=0
-x=0
3x-5y=0
If I take "y" to be the free variable, I have x=5/3y therefore the solution to the system will be
\begin{bmatrix} {x \\ y\\z \end{bmatrix} = \begin{bmatrix} {5/3 \\ 1\\0 \end{bmatrix} y + \begin{bmatrix} {0 \\ 0\\1 \end{bmatrix} z
But if I take "x" to be the free variable I get y=3/5x, so I get the following solution:
\begin{bmatrix} {x \\ y\\z \end{bmatrix} = \begin{bmatrix} {1 \\ 3/5\\0 \end{bmatrix} x + \begin{bmatrix} {0 \\ 0\\1 \end{bmatrix} z
How do I know which one (x or y) should be taken as the free variable?
Could anyone please explain to me how to get the right answer? :frown: I just can't see how to deal with this type of problems.
x=0
-x=0
3x-5y=0
From these equations, x is obviously 0. With x = 0, the 3rd equation implies that y = 0. This means that z is the free variable.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
