System of two inclines planes and pulleys
The problem involves a system of two particles connected by a string over pulleys, with the particles on inclined planes. The setup includes considerations of mass, friction, and equilibrium conditions, specifically focusing on determining the coefficient of friction and the mass of a moving pulley.
  • Participants discuss the equilibrium conditions of the system, equating forces acting on the particles and the pulley. There is an exploration of the relationship between the forces and the unknowns involved, particularly the coefficient of friction and the mass of the pulley.
Some participants have provided guidance on how to manipulate the equations to isolate the unknowns. There is an acknowledgment of the conditions of the string and pulleys, which simplifies the analysis. The discussion is ongoing with participants seeking clarification on the implications of their equations.
Participants are working under the assumption that the system is in equilibrium and that the string is light and inextensible. The angles of inclination and the coefficient of friction are central to the problem but remain undefined at this stage.
deea11235
The diagram shows two particles, A of mass 5m and B of mass 3m, connected by a light
inextensible string which passes over two smooth, light, fixed pulleys, Q and R, and under a
smooth pulley P which has mass M and is free to move vertically.
Particles A and B lie on fixed rough planes inclined to the horizontal at angles of arctan(7/24) and
arctan(4/3) respectively. The segments AQ and RB of the string are parallel to their respective
planes, and segments QP and PR are vertical. The coefficient of friction between each particle
and its plane is μ.
1)Given that the system is in equilibrium, with both A and B on the point of moving up
their planes, determine the value of μ and show that M = 6m.
2)In the case when M = 9m, determine the initial accelerations of A, B and P in terms
of g.
Diagram is here: http://www.picpaste.com/pics/fizik-3suPlHIQ.1377787280.png
Well for starters at 1) if we were to note [itex]\vec{TA}[/itex] and [itex]\vec{TB}[/itex] the vectors for the forces of the strings coming from A and B respectively and considering that the system is in equilibrum, equating the the forces gets us Gp=TA+TB, and considering each inclined plane and the force of friction going downwards (the system is on the point of moving up) we get TA=GA+Ff=mA*g*sin(arctan(7/24))+μ*mA*g*cos(arctan(7/24)). Doing the same thing for B and after the substitution in the first equation I get mP=mA(sin(arctan(7/24))+μ*cos(arctan(7/24)))+mB(sin(arctan(4/3))+μ*cos(arctan(4/3))). Problem is, here I have only one equation and two unknowns: mP and μ. What am I doing wrong? :(
Try to subtract the equation you attained for TA from the equation you attained for TB. This will leave the unknown μ.
You mean TA-TB? But what would I equate it to? Is TA-TB=0, in which case, why?
TA=TB since the string is light and inextensible, while the pulleys are smooth. The sole purpose of the pulleys here are to reorient the string.
An extensible string is like a spring and a 'light' string is one we take to be of zero mass. These conditions at the start simplify the analysis.
That was what I was missing, thank you!
  • · Replies 68 ·
14K
  • · Replies 22 ·
  • · Replies 22 ·
