How Do Satellite Tangential Speeds Compare to Earth's Orbital Momentum?
  • Thread starter Thread starter avito009
    Earth Speed
The discussion focuses on the comparison of tangential speeds of satellites and Earth's orbital momentum. Tangential speed is defined as the linear speed of an object moving along a circular path, crucial for maintaining an orbit. Both satellites and Earth possess momentum that prevents them from drifting towards the Sun or each other. Launching satellites towards the East, particularly from the equator, optimizes fuel efficiency by utilizing Earth's rotational speed of approximately 1000 mph.
  • Understanding of Newton's Second Law of Motion (F=ma)
  • Knowledge of orbital mechanics and types of orbits (circular, elliptical, parabolic, hyperbolic)
  • Familiarity with satellite launch dynamics and equatorial launch advantages
  • Basic concepts of momentum in physics
  • Research the mechanics of elliptical and hyperbolic orbits
  • Study the effects of Earth's rotation on satellite launch trajectories
  • Explore advanced concepts in orbital dynamics using software simulations
  • Learn about the physics of momentum and its applications in space travel
Aerospace engineers, physics students, satellite launch planners, and anyone interested in the mechanics of orbital motion and satellite deployment strategies.
avito009
Tangential speed is the linear speed of something moving along a circular path. So for a satellite the tangential speed of the satellite is just right so that gravity only has the effect of changing the direction of travel.
So now can we compare this satellite to the Earth? Since the Earth has some initial momentum - it is moving in a direction,which is perpendicular to the direction of the Sun from the Earth.
So that means both the satellite and the Earth have (Initial) momentum that prevents them from getting close to the Sun or Earth (In case of satellite).
You don't need the "initial" part. Any orbiting body possesses momentum.
In a perfectly circular orbit, yes. Objects in elliptical, parabolic, or hyperbolic orbits will not have a steady speed.
You are correct. Every object on Earth already has the velocity needed to orbit the Sun, whether it is on Earth or not. To put a satellite in orbit around the Earth, it is easier to launch it toward the East so that its velocity on the surface of the rotating Earth can help it reach the orbital velocity. The advantage is larger on the equator than in the U.S., and there is no advantage at the North Pole.
Ok so you mean that according to Newton's Second Law of Motion, the Force Law, the effect of a force on an object is to accelerate it in the direction of the force, according to the formula
F=m a
So the direction of the force of the Earth is towards the East as it rotates towards the East. Now if we were near the Equator we would move at 1000 mph speed. So a spacecraft launched from near the equator would need lesser fuel and would acquire the speed of 1000 mph. So since the direction of force is to the East and velocity is 1000 mph then the satellite also travels in the direction of this force.
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 28 ·
  • · Replies 18 ·
