Tangential Velocity Homework: Calc Attractive Energy/Force & Find Min Velocity
The problem involves calculating the attractive energy and force between water molecules and a carbohydrate gel during centrifugation. It also requires determining the minimum tangential velocity needed for the water molecules to separate from the gel at a specified distance.
  • The original poster attempts to calculate the attractive energy per molecule and the attractive force, but expresses uncertainty about finding the mass needed for further calculations. Some participants question the dimensional consistency of dividing energy by distance to obtain force.
Participants are exploring various aspects of the problem, including the conversion of energy units and the application of relevant equations. Some guidance has been offered regarding the use of specific formulas, but there is no explicit consensus on the approach to take.
There is a mention of the need to convert energy units from kJ to Joules for consistency with SI units. Additionally, the original poster has received hints from their professor, which may influence their approach to the problem.
Priscilla
A carbohydrate gel is being centrifuged to remove excess physisorbed water. Assume that the magnitude of the attractive energy between the water molecules and the gel is given by 3.63 kJ/mol of molecules of water, with the water molecules being separated from the surface of the gel molecules by 0.4 nm.
a)Calculate the attractive energy per molecule of water, and the attractive force between one molecule of water and one gel molecule.
b)Assuming that the gel in the centrifuge has a radius of curvature of 0.5 m when the centrifuge rotates, find the minimum tangential velocity with which the centrifuge needs to rotate in order for water molecules to just begin to separate from the gel molecules, at a separation of 0.4 nm
N_A = 6.02*10^23 molecule/mol
E=fr
F_c = mv^2/r
The attractive energy per molecule of water
E = 3.63kJ/mol of molecules of water
E = 3.63kJ/mol / 6.02*10^23 molecule/mol = 6.03*10^-24 kJ/molecule of H2O
The attractive force between one molecule of water and one gel molecule
E = fr
f = E/r = (6.03*10^-24 kJ/molecule) / 0.4*10^-9m = 1.51*10^-14 N/molecule of gel
The minimum tangential velocity
F_c = mv^2/r
F = 1.51*10^-14 N r = 0.5m
I know I can use this equation to find the velocity, but I don't know the mass. How can I find the mass?
Anyone know how to solve this?
Priscilla, 99,9% of posts in this section can be solved with the formula F=ma.
Your question is yet advanced, try posting it in Advanced Physic or Chemistry.
For myself, I am an electronic and I didn't even know that the attractive energy is measured in kJ/mol.
I'm going to read something about it because it looks interesting, and maybe let you know any idea.
What I find strange is that you divide an energy by a distance, and you get a force.
Dimensionally, I don't know if it makes sense.
But, again, I'm pretty ignorant about.
Best things.
Thanks for your reply.
Our prof gives us some hints that, we could use F=fr which is derive from the intermolecular forces:
E(r) = 4e[ (s/r)^12 - (s/r)^6] s = lower case sigma
=> f = -dE/dr
=> E=fr
You need to change kJ to Joules, since Joules is the SI Unit. The dimensionality will make sense then.
11K
12K
