How to compute a Taylor expansion for f(x,y) using Mathematica?
The discussion focuses on computing a Taylor expansion for the function f(x,y) using Mathematica's Series function. The correct syntax is Series[f[x,y],{x,0,1},{y,0,1}]. Users encountered zero terms in their expansions, which were clarified as O(y+2)^2, indicating higher order terms rather than actual zeros. To eliminate these terms, the Normal function should be applied: Normal[Series[...]].
  • Familiarity with Mathematica programming language
  • Understanding of Taylor series and their mathematical significance
  • Knowledge of function expansion techniques
  • Basic experience with symbolic computation
  • Learn how to use the Normal function in Mathematica for simplifying series expansions
  • Explore advanced features of Mathematica's Series function
  • Study the implications of higher order terms in Taylor expansions
  • Investigate symbolic computation techniques in Mathematica
Mathematics students, researchers in computational mathematics, and anyone using Mathematica for symbolic computation and function analysis.
chinaman209
Can someone pls explain hot to compute a taylor expansion for f(x,y) using mathematica
When I expand like that i get some zero terms like 0(y+2)^2.. and so one repeated a finite number of times. When i try to simplify the answer the zeroes don't go away. So are these really zero?
Those are not 0 (number zero) they are O (letter "Oh"). The term O[y+2]^2 means an unspecified term of order (y+2)^2 to represent all of the higher order terms in the expansion. If you want to get rid of it then just use:
Normal[Series[...]]
