Temperature of the surface of a satellite?
The discussion revolves around estimating the temperature of a satellite's surface, considering various factors that influence thermal conditions in space. Participants explore theoretical aspects, practical implications, and the complexity of heat transfer in the context of satellites.
  • Some participants suggest that the temperature of a satellite's surface can vary widely, potentially being as cold or as hot as the Moon's surface, depending on various conditions.
  • Heat generation and transfer are highlighted as critical factors, with the sun-facing side of the satellite becoming quite hot and the opposite side potentially becoming very cold.
  • Reflectivity and emissivity of the satellite's materials are noted as key elements affecting radiative energy transport.
  • One participant mentions that calculating the temperature is complex and may require direct measurements from temperature sensors on the satellite.
  • Factors such as the satellite's orientation to the sun, internal heat sources, and distance from the sun are also discussed as influencing temperature.
  • A reference to the Stefan-Boltzmann law is made, suggesting its relevance to the discussion of thermal dynamics in satellites.
Participants generally agree that multiple factors influence the temperature of a satellite's surface, but there is no consensus on a specific temperature or a straightforward method to calculate it. The discussion remains unresolved with various competing views on the complexity of the issue.
Limitations include the dependence on specific material properties, the need for precise definitions of terms like emissivity and reflectivity, and the unresolved nature of mathematical calculations related to thermal dynamics.
pixel01
Anybody has an idea about that?
Thanks
Astronomy news on Phys.org
Are you asking what the temperature is? It depends on a lot of factors and there is no one answer.
Thanks for your answering.
May I thing of an estimate. Could it be as cold as the Moon surface? No atmosphere, the same distance to the Sun..
Yes, it could be as cold as the moon's surface -- or as hot as the moon's surface.
It's complicated depending on heat generation and transfer from the satellite.
The surface facing the sun can get quite hot, while the surface away from the sun can get quite cold.
Reflectivity and emissivity are two key factors affecting radiative energy transport.
I'm just a college freshman, but if you think about it, there are so many factors that can affect this. It depends on how much heat the material of the satellite's surface absorbs and reflects. Also, it depends whether it is facing the sun with or without the obstruction of another satellite or heavenly body. There is really no way to "calculate" this; the only way to do it is to use a temp sensor on the satellite itself. Good question, though, it got me awake and thinking this morning.
Knowing the materials used to cover the satellite helps, also its distance fom the sun and its proximity to the earth.
Its a classic Stephan Boltzmann thingy - Joe Satrianni has got the idea.
Reflectivity and Emissivity. - Nicely done Joe
hey pixel,
i covered this stuff in a final year mechanical and space engineering degree and there is an equation that exists to work it out, however finding that equation is quite difficult. i have it buried somewhere in my old notes somewhere and if i can be bothered finding it when i get home i'll let you know.
a quick answers is that it isn't cold at all, it depends on several factors. I will try to list them;
- the emissivity and reflectivity of the satellite material
- the orientation of the satelite to the sun which will determine the surface area exposed to the suns radiation
- internal heat generation of the satelite itself e.g. batteries, fuel cells, solar panels etc.
- distance from the sun
- there are a few constants chucked in there as well :S
i will try and remember to find the equation when i get home... you have me intrigued again :P
  • · Replies 0 ·
  • · Replies 36 ·
9K
  • · Replies 22 ·
