Tension and speed at different points of a swinging pendulum
48 replies · 7K views
Helly123
For number 3,4,5
https://s4.postimg.org/qbp3xzq65/IMG_1092.png
https://s22.postimg.org/u220j60sx/IMG_1093.png
Centripetal force = m v^2/R
T = centripetal force + w
Sigma F = m.a
Number 3. Find the v at D point using mechanic energy eternity
While kinetic energy at A point is zero, and the potential energy is max (height max)
So, 1/2mvD^2 + mg.hD = 1/2mvA^2 + mg.hA
i don't know the height at D point...
After i find the v at D
I can find T
Which T = centripetal Force + weight
T = mvD^2/R + m.g
Number 4 almost the same
The string doesn't bend (what exactly it means...?)
So, centripetal force > weight??
m.vD^2/R > m.g ...(1)
But why the centripetal at point D has opposite direction than weight force? Is it because the string stuck at the nail at C point??
Find the v at D using mechanical energy eternity then add v to ...(1)
Number 5 i still don't know...
Hello Helly, :welcome:
Unfortunately your pictures don't show up in your post. I get:
Can you try again ?
Can you try again ?
ok.. thanks for report. I've changed the pic.. :)
with ##v_A = 0 ##.
make a sketch of the situation and you know it. Note that CB = CD.
You know the length of the string, and you know how far C is below A. How far above C is D?
is the height of D start from C or B ...?
CD = a-b
BC = a-b
if D start from C then height of D = a-b
if D start from B then height of D = 2(a-b)
Check your energy conservation equation: If A is at height zero, you must take height of D wrt the same referernce.
if A = height zero.. then kinetic energy is max...
then B point the kinetic energy is zero... how can it be...
It was you who chose height A = 0 ! Therefore at point B the height is -a and the energy conservation still reads $$
{1\over 2} mv_B^2 + m g h_B = {1\over 2}mv_A^2 + mg\,h_A \quad {\rm or} \\
{1\over 2} mv_B^2 - mga = 0 $$
hmm I see..
then it said the string doesn't bend, how that means Sir??
As long as you have tension in a string, it does not bend but remains taut.
First work out number 3, once you have that, then number 4 is easy
By the way, what did you get for number 2 ?
Do you realize image 1093 is extremely fuzzy ?
number 2? I get sqrt 2ga. do you even know the questions Sir.. but I'm still trying for number 3...
Very unsharp, in image 1093 under (2) It says: Find the magnitude of the tension in the string just before the small ball reaches B.
##\sqrt{2ga}\ ## is not among the choices. But also, 2mg ...
Is the wrong answer (as I already suspected :rolleyes: ) .
You need to get this right: the same issue also needed in (3).
lol.. sorry Sir. I meant 3mg..
BvU said:
Agree with 3mg.
oh... it's my mistake... lol i'll try again number 3.. how do you even know the question for number 2, from the pic there's no number 2
BvU said:
I know that.
I don't even understand... How to solve number 3...
At point D you know the speed from energy conservation.
So you know ##mv^2/r##.
Take gravity into account and then you have T.
No the problem is idk the speed.. And not sure the height of D. If the string not bend, it's possible if only the string stuck at nail on C point then goes around to D, it means the height of D is a-b. The v^2 at D = 2gb.. Then.. I don't find the answer match the options
with respect to what reference point ?
Helly123 said:
The v^2 at D = 2gb
How do you calculate that ?
Do you know the answer already?
CB = a-b
CD =CB
CD = a-b.
Suppose a is 0.5 m and b is 0.4 m. What is the height of D ?
What is the formula for the height of D with your reference point O = 0 ?
Since the ball goes around to D point, the reference i used no longer O=0 but C.. Cuz the T is at C.. No i used is at O the height is a (max)
we know that OC = b (0.4 m)
Then CB = a-b (0.5-0.4)m
Then CB = 0.1m
CD = 0.1m. Then use CD as height of D
