Tension Force problem involving friction
A horizontal rope pulls a 20 kg sled with a 5 kg box on it across frictionless snow, and the goal is to determine the maximum tension force before the box slips. The coefficient of static friction between the box and sled is 0.5, leading to a maximum static friction force calculated using Ff = mu x n. The box does not accelerate, so the tension must equal the maximum friction force to prevent slipping. After applying Newton's second law, the maximum acceleration of the sled is found to be 4.9 m/s², resulting in a tension force of 73.5 N. The calculations confirm the correct understanding of the forces involved.
chimbooze
1. A horizontal rope pulls a 20kg wood sled across frictionless snow. A 5 kg wood box rides on the sled. The coefficient of static friction for wood on wood is 0.5. What is the largest tension force for which the box doesn't slip?
m = 5 kg box, 20 kg sled
mu = .5
T = ?
2.
F = ma
Ff= mu x n
3.
F = ma
a of box is zero since it is not moving
T - mu x (20 + 5) x (9.8) = 0
No, both sled and box are accelerating. (They're being pulled by a rope.)
Hint: What is the maximum static friction between box and sled?
I partially get it. If Tension force is greater than the static friction force, then the box will move. So just find friction force.
Ff = mu x n
Ff = .5(9.8)(5)
But that isn't the right answer.
That's just one step toward the answer. Now that you know the maximum friction force on the box, what is the maximum acceleration that the sled can have without the box slipping?
To get the final answer, you'll need to apply Newton's 2nd law twice.
So:
sum of F = ma
Ff = ma
.5(9.8)(5) = 5(a)
a = 4.9
Tension of rope: T = ma
T = (10 + 5)(4.9)
T = 73.5
Thanks a lot. I got it correct.
Excellent!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
